Author Topic: Daylight Power Grooves  (Read 210 times)
static1701
Scott
Daylight Power Grooves « on: March 12, 2010, 08:06:07 AM »
http://www.youtube.com/watch?v=k_45q5ABK6E
Take a NOS Preheat ballast and a new electronic ballast and wait 40 years. Which one will still be working? Preheat...nothing better!
Fox Mantra
Philips Sl Comfort best bulbs
Re: Daylight Power Grooves « Reply #1 on: March 14, 2010, 05:16:19 PM »
Nice bulbs,  i like how your camcorder makes the bulb go all colourful in time.
Techno, Lightning, PS3, Lights, Furry, Random bloke.
Sr. Member
Re: Daylight Power Grooves « Reply #2 on: May 17, 2010, 02:29:38 AM »
Several of the "slow" instant start electronic CFLs (Includes the recent Philips Genie CFLs) behaves like these powergrooves during ignition despite their ballasts is significantly different and also their ignition mothed (Powergrooves uses rapidstart magnetic ballasts).
Rapidstart magnetic ballasts and all electronic ballats for argon buffer based fluorescents that emulate the rapid starting of these magnetic ballasts warms the electrodes while applying to the tube its operating current without any high voltage (One of the reason why Krypton can't be used with these ballasts). After a few seconds, when the electrodes heated enough, the lamp stabilizes itself. In instant start CFLs on the other hand, the ballast send to the lamp a high voltage and a lower current to operate it in cold cathode mode and then transfers the operation to hot cathode modes. Despite this, several instant start CFLs, like the recent Philips Genie lamps, lits exactly like these powergrooves in this video which uses magnetic rapidstart ballast. Why?
« Last Edit: May 17, 2010, 01:40:15 PM by dor123 » Logged
nogden
Nelson Ogden
Re: Daylight Power Grooves « Reply #3 on: May 17, 2010, 03:03:49 PM »
Is that a lead-lag ballast? I'm just wondering why the lamps seem to be "firing" at different times.
Nice light!
static1701
Scott
Re: Daylight Power Grooves « Reply #4 on: May 17, 2010, 06:06:41 PM »
I don't recall the info on the ballast, I know it is an Advance rapid start VHO.
In person, the bulbs don't blink or flash. I guess they are really doing that but with out the camera...you just can't see it.
RCM442
Re: Daylight Power Grooves « Reply #5 on: July 27, 2010, 11:45:21 PM »
What you are seeing is frequency switching, since US power runs on 60 HZ, the camera can see it, and it makes the lamps appear to flash, but you can't see it with your own eye!
TiCoune66
Sr. Member
Frost PH ballasts, surely the best ones I've seen!
Re: Daylight Power Grooves « Reply #6 on: July 28, 2010, 03:08:30 PM »
That is indeed the lead-lag effect, or "stroboscopic correction". Most magnetic ballasts, including the popular Tulamp preheat ballast use that configuration.
I'm also known as Vince the fox.
I still use old lighting technology, it has absolutely no environmental impact, because my house is fed by hydroelectricity. ^_^
Pages: [1] Print
