Author Topic: A Siemens SL100 lantern with a cycling HPS lamp  (Read 3499 times)
A Siemens SL100 lantern with a cycling HPS lamp « on: August 27, 2010, 05:01:01 AM » Author: dor123
http://www.youtube.com/watch?v=Z51vMW4-8m8
This lantern photographed early in the morning in 05:40 (Israel clock), and this is the reason for the blackness in this video.
This lantern uses superimposed ignitor to reignite the lamp.
« Last Edit: June 04, 2011, 02:35:27 PM by dor123 » Logged
magslight
Re: A Siemens SL100 lantern with a cycling HPS lamp « Reply #1 on: September 04, 2010, 05:53:55 AM » Author: magslight
Have you only seen one cycling ?
SuperSix
ATL P42STUFF supersix94
Re: A Siemens SL100 lantern with a cycling HPS lamp « Reply #2 on: September 04, 2010, 12:49:33 PM » Author: SuperSix
There's a supermarket near me that uses SON lamps and there's always some that cycle. Once I saw a group of 3 together all randomly cycling on and off, they seem to lack any proper maintenance staff there.
Not meaning to change the subject but have either of you two ever seen a mercury cycle?
magslight
Re: A Siemens SL100 lantern with a cycling HPS lamp « Reply #3 on: September 04, 2010, 01:00:41 PM » Author: magslight
@Eliot_240: I've never seen a MV cycling.
Re: A Siemens SL100 lantern with a cycling HPS lamp « Reply #4 on: September 04, 2010, 02:13:02 PM » Author: Medved
I had one cycling, but it was more a result of an old, but not uch used lamp combined with regular mains voltage dips (from wood chopper varying load).
New lamp "survived" this without extinguishing the arc...
Re: A Siemens SL100 lantern with a cycling HPS lamp « Reply #5 on: September 05, 2010, 04:40:22 AM » Author: dor123
@magslight: I had saw many HPS and MH lamps cycling. Several do like the lamp in this fixture and others just flashed in a fixed speed until they turned on.
I have other videos of reignitions of cycling HPS lamps in the forum.
