Hello Everyone. Although I am new to this site, I see there is a wide demographic of collectors here from the highly expierenced, such as James and Max, down to many eager "Newbies" from all over the world! As an expierenced collector with 44 years collecting I would like to propose a method by which all expierenced collectors can standardize the way they present lamp data and a method by which the "Newbies" can learn about the lamps that they are collecting. I am only a lamp collector, I do not collect Lanterns/Luminares, and as such this discussion mainly concerns lamps. Those who do collect Luminares way well be able to construct their own database templates specifically for luminares and, as a consequence allow members such as myself, somewhat ignorant of luminares, to lean about them. I started keeping a database on paper in 1987 when my collection had got to about 2500 lamps and my memory alone was not enough to keep track of them. Since that time the number of lamps has increased four fold and the database has evolved into a 90 field bohemuth. One may feel that 90 fields is far too many, but in my expierence, they are all necessary. So, I will list the fields and a couple of lamps entered as examples and try to assess the interest of members by their replies......
Field Name Lamp Example 1 Lamp Example 2
General Humanities Fields Field No.1 BRAND......................General Electric.......................Sylvania Field No.2 UNIQUE IDENTIFIER..........07-033.................................12-179 Field No.3 COLLECTION.................Globe Collector........................Globe Collector Field No.4 COMPANY....................General Electric Inc...................Osram GmbH Field No.5 MANUFACTURER...............N.E.L.A. Pk. Cleveland OH .............Spandau, Berlin
Descriptive Fields Field No.6 TYPE.......................160mm U.S. G.L.S. .....................CMI-T 70W/NDL/SB Field No.7 POWER RATING...............1000W .................................70W Field No.8 VOLTAGE....................120V Ext. .............................100V Int. Field No.9 BULB/ENVELOPE, (Met).......PS-160/315 ............................TQt-18/100 Field No.10 BULB/ENVELOPE, (Imp).......PS-50/100 .............................TQt-5.6/317 Field No.11 Bulb Finish ...............Clear .................................Clear, U.V. Stop Field No.12 Finishing Method ..........None...................................CeO2 doped Silica Field No.12 Etch/Emblem................On Crown, Circular Fmt. Dk Brn ........On Cap,Txt Fmt,Bk Field No.13 Etch Visibility............Poor ..................................Good Field No.14 Etch Durability............Poor ..................................Excellent Field No.15 Cap/Base (Intl. Code)......E39/40 ................................G12/30x32 Field No.16 Cap/Base (Word Desc.)......Mogul .................................Sym Pin 12mm Field No.17 Cap/Base Materials .....Brass, Black Viterite and Lead ....Ceramic, Ni Plated Brass Field No.19 Cap/Base Fastening ........Heat-Cured Cement .............High Temp Zirconia Cement Field No.20 Bulb Filling ..............Argon, Nitrogen ........................Vacuum Field No.21 Filament ..................1AX ....................................N/A Field No.22 Arc Tube/Inner Bulb .......N/A ....................................AAXR2 Field No.23 Filament Material .........Doped Tungsten .........................N/A Field No.24 Arc Tube Filling ..........N/A .................Ar, Hg, NaI, TlI3, CeI3, SnI4 Etc. Field No.25 Button..................Glass Rod Between Lead Ins ................N/A Field No.26 Button Rod..............Glass 40mm, Truncated .....................N/A Field No.27 Heat Deflector Disc.....Mica.......................................N/A Field No.28 Disc Position...........Clipped to Lead Ins above Press............N/A Field No.29 Stem....................Long, 53mm ................................N/A Field No.30 Arc Tube Contents ......N/A ..............Ar, Hg, NaI, TlI3, SnI4, CeI3 Field No.31 Electrodes ..............N/A .........Thoriated Tungsten with heat radiator coils Field No.32 Arc Tube Seals .............N/A .........Niobium Wire through Sitnered Aluminia Field No.33 Seals .................Dumet through Boro Glass ...Molybdemum Foil Through Silica Field No.34 Getters ............Phosphorus Pentanitride, Red P? ....Zirconium/Aluminium Pellet Field No.35 Fuses .....................? ...............................Moly Foils in Seal? Field No.36 Exhaust .....Stem Concentric, Mitchell and White .............On Crown of Outer Field No.37 Arc-Tube or Inner Exhaust ..N/A .........................During Arc Tube assembly
General Demographic Fields Field No.38 Country of Origin ..........U.S.A. .........................Germany (ReUnified) Field No.39 Date and Factory Code ......Not Visible ............................q638 Field No.40 Circa Date .................c1965 ...................................March 2006 Field No.41 Lamp Aqusition Date ........28th February 2007 .....................22nd May 2012 Field No.42 Lamp Aquisition Place ...Yersin Matket, SaiGon VN .........Melbourne City Council
Lamp Condition Fields Field No.43 Condition ..................Works .................................Works Field No.44 Level ......................100% ..................................20% Field No.45 State ......................New ...................................Used/E.O.L. Field No.46 Packaging Status ......Without Original Packet ...............Without Original Pkt Field No.47 Packetmates ................N/A ...................................N/A Field No.48 Packet Details .............N/A ...................................N/A
General Family Sorting Data Field No.49 Class ...................Incandescent Filament ...........High Intensity Discharge Field No.50 Family ..................Industrial G.L.S. .................Metal Halide, Ceramic Field No.51 Schema (Bulb Nesting)....SE-SJ-G ................................SdE-DJ-CQ
Photometric Data Field No.52 Spectrum .Black-Body Continuum .(Dop. Pres. Brdnd) Atomic Lines of Na, Tl, Ce, Sn. Field No.53 (Corrected Colour Temp).....2700 ..................................3000 Field No.54 C.I.E. -X ..................0.453 .................................. ? (New) Fleld No.55 C.I.E. -Y ..................0.416 .................................. ? (New) Field No.56 C.R.I. ......................100 ....................................87 Field No.57 Ra Group ....................1A .....................................1B Field No.58 Light Output, lm ............c1400 .........................6700 (Luminous Flux) Field No.59 Light Output, Intl. C.P......c112 ........................533 (Luminous Intensity) Field No.60 Luminous Intensity, Lux .....? ......................................? Field No.61 Efficacy lm/W ...............c14 ....................................96 Field No.62 Efficiency ..................c30% ...................................c70%
Electrical Data Field No.63 Cold Resistance ..............1 Ohm .........................V High, Voltage Dep. Field No.64 Hot Resistance ...............16 Ohms ................................c150 Ohms Field No.65 Hot to Cold Ratio ............16 : 1 .................................0 : 1 Field No.66 Raw Electrical Data ..........7.74A@120v, 7.91A @ 125v................980mA Field No.67 Measured Power ...............929W-989W ..............................? Field No.68 Control Gear .Low Source Impedance 120v, 30-800Hz.. 650mH, 1.5A Choke in series off 240v 50Hz Field No.69 P.F.C. Cap ...................N/A .........................12uF 630v N.P. Film
Misc Data, Field No.70 Burning Posn. ................Universal ..............................H-90 Field No.71 I.L.C.O.S. ...............IAA-C-1000-120-E39-160 .....MT-70/30/1A-H 90/S-G12-19/100 Field No.72 Nett Mass (g) ................? ...................................... ? Field No.73 Nett Mass (lb,OZ).............? ...................................... ? Field No.74 Gross Mass (g) ............Not Obtainable .....................Not Obtainable Field No.75 Gross Mass (lb,OZ).........Not Obtainable.......................Not Obtainable Field No.76 Stated Life, h ...............1000 ....................................6000 Field No.77 Statistical Actual Life ......? ........................................ ?
Asthetic Data Field No.78 Justification ............North American Realm Lamp ....Power Ball, Sylv bgd Osram Field No.79 Uniqueness ...........Only one in this collection .. Only one in this collection Field No.80 Asthetics ............Impressive Large,........Curious Looking Complex Intreaguing Field No.81 Comment 01 ...........Axial Filament ..............Sylvania Branded , Osram Patent Field No.82 Comment 02 ................Bits of Biotite in Disc ..........Strong Thallium Line
Economic Data Field No.83 Economic Status......Foreign Within Australasian Realm ............Import Field No.84 Capital Cost at time of production .....$? .......................Euro? Field No.85 Price Paid to Acquire ............25000VND .............................Nil Field No.86 Intrinsic Value ...................AU$ 250 .............................AU$ 25 Field No.87 Extrinsic Value ...................AU$ 30 ..............................AU$ 10 Field No.88 Depreciation .......................30% ................................75%
Other Field No.89 Identicals .........................None ...............................None Field No.90 Providence .............Used by U.S. Forces in VN War ......Used in St Kilda Road Field No.91 Comparasons ..................None ......................................12-178 Field No.92 Set Members ..................None in this Collection ...................12-178 Field No.93 Fate .............................Primary ................................Primary Field No.94 Industrial Standard ..............A.N.S.I. ? ...........................? Field No.95 Geographical Realm .............North America ..........................Europe Field No.96 External Symmetry .........x = Inf, Y = Inf, z = 1 .............X = 2, Y = 2, Z = 1
Many of these fields use industry standard notation, e.g for bases and caps. Everybody here would know the cap on a PAR-38 this is designated E27 or E26 in short notation, but because of the collar the notation is often extended to include the diameter of the large part of the collar and the length, so it becomes E27/39x51 (in metric mm) for this specific type of cap. Some of the fields here use a modified form of code, based on the industry standard, but embellished to delineate nuances. The type "A" arbitary bulb shape is a case in point. In the European realm the neck is short and thick and the bulb to neck transition has a small radius. The European A-60 (and other sizes) also has a pronounced "shoulder" at the neck to cap transition. By contrast, the North American Realm bulb has a large radius curve from the bulb to cap and no shoulder at the cap. The codes "AE" and "AA" are used to delineate these forms. A small letter "t" indicates the presence of an exhaust tip on the bulb crown. Numbers following the type indicate the dimensions in mm (metric) and eighths of an inch(imperial). Some codes have been totally artificially concocted because age-old industry standards are inadequate. The two cases in point are filament structure and arc tube codes. Unlike any industry standard filament codes, the codes used here commence with a number or sometimes numbers and conclude with Roman letters or sometimes Roman Letter/Arabic Numeral combinations. The numbers indicate the number of support wires, and if more than one, groups of support wires whilst moving from the crown to the cap. So a flat grid projection lamp with three upper supports on the crown end and two lower supports at the cap end will possess a code like 3,2FG. If biplane, then 3,2BP. Axial filaments, parallel to the axis of symmetry of the bulb get a suffix, "AX", whilst those parallel to the equatorial plane or in the equatotial plane get "TV", for "Transverse". Arc tubes get similar treatment, with the first letter delineating the material, G = Glass, Q = Fused Silica, A = Sintered Aluminia. C = composite/graded seal types. The electrode chambers get a letter, C = conical, R = Spherical, C = Cylinderical. Other letters indicate probe or starting electrodes at crown or cap ends (or both) and any corona wires, bi-metallics or screen printed "antennas". In the case of aluminia arc tubes, the number of assembled pieces is listed. Some of the higher numbered fields may be somewhat cryptic, such as Field No.51, "Nesting Schema". This indicates whether or not the lamp is single bulbed or double bulbed, such as a Mercury Lamp with an arc tube inside an outer bulb. This also indicates whether the bulb is double ended or single ended. A typical code would be "SE-SJ-G", which reads as "Single Ended, Single Bulbed, Glass Bulb". Whereas "SdE-DJ-CQ" reads "Single Ended outer, double ended inner, Double Jacketed, Sintered Alumina Ceramic inner, Fused Silica "Quartz" outer. Thus these codes give one an overall quick impression of the lamp being described. A lower case letter in the centre group, i.e "SE-tJ-QQG" indicates that there is triple nesting with one nested bulb atmosphere unsealed. e.g Sylvania HSI-MP 100W CL/4K with a silica explosion shield around the arc tube. Some other fields are... 78 "Justification", i.e Why did you include the lamp in your collection? 79 "Uniqueness", i.e Is there another like it in the collection, is it a rare lamp? 80 "Asthetics", This is a field which can be difficult to fill for a male, but hold the lamp up in front of your wife or girlfriend and ask her if she thinks it is ugly! Try to get her to quantify jusy how beautiful or ugly it is!
86 "Intrinsic Value". i.e Of what value is the lamp to you. How much effort and time did you expend to acquire it? How far did you travel to get it? How difficult was it to separate it from its previous owner? 87 "Extrinsic Value". How much could you convince an insurance company to "cough up" for it if it were destroyed? How much would you expect to get for it if you sold it on E-Bay say? 92 Here is listed the unique identifiers of any other lamps which are related to this one. E.G. If you have a Sylvania H37KC250DX from Trois Riviers on Quebec made in 1978, and you also have a Sylvania H33GL400DX from the same plant and roughly the same age, listed in the same product catalogue, then the two a "brothers" and part of the same "SET". Whereas a General Electric H37KC250DX from Ravenna Ohio with a girder frame would be listed in the "comparisons" field, as not the same set, but an equivalent from a different company, branded differently and made in a different plant!
93 "Fate" Is it your only one?. Would you swap or sell it if someome else asked you. "Primary" means that it stays in your collection at all costs. "Secondary" means you might swap for something equally as good but you loose your "breakage spare". "Tertiary" means that you have three and it is generally available for sale or swap.
If we were all to keep such a database, comparing lamps, sawpping lamps and getting the story for each lamp would be much more uniform. I'm sure that stamp and coin collectors would possess a much more uniform way of describing what they have to each other. I'd love to see a new word in the dictionary for "lamp collector", much akin to the word "philatelist" for a stamp collector. I feel that this would give a much more solid label to what we do and what we are interested in. Maybe we should all submit a word which we think would describe what we do and then we could all etymogically vote for the best term agreed by us all to describe us best. Currently I am trying to get a web-site up and operating, but getting all the bits to "talk" to each other is a nightmare. A hind-end database , such as S.Q.L. is required. A Wiki-Like fromt end is also needed to handle the user's queries and something to generate html pages for each lamp queried from the database is also needed to get the pictures, data and other relevant stuff and display it to the user/surfer. A non-wiki static part of the web-site is also needed to hold all the technology, history and other stuff relaated to lamps in general.
Your collective comments please!
Below are images of the two lamps in question.... |
