Hi all, I recently ran some tests which involved running loads of significantly varying arc voltage on my two HPF F40T12 rapid start ballasts, my vintage CGE and my Advance R-140-1-TP. I found a side effect in running these tests which, interestingly, is handled very differently between the two ballasts.
As we all probably know, as arc voltage goes down on an HPF ballast, total system power goes slightly down, as well. Mains voltage remains constant, so that means either line current or power factor must be going down. I found that on the Advance, line current goes down and power factor remains the same, while on the CGE, line current remains the same, and power factor goes down!
Does anyone suppose how this difference in power regulation works? Perhaps a difference in where the capacitor is wired?
