The meters usually use the ZigBee, which is encrypted, low bit rate, low power (supposed to operate from a single use Li battery for years even with rather cheap radio design) protocol working in the license-free 2.4GHz band. And for that band, the legal maximum limit for any license free use is 100mW ERP (the real maximum transmitter power is adjusted according to the gain/losses of the used antenna), but in most cases the signal quality management commands for way less (to save power, as well as radio band space). That is way less than the mobile phones or so. The thing is, the low bit-rate (around 1kbps) allows to reach rather great distances (way longer than the broadband WiFi specification expect with the same 100mW ERP limit). So even 50 meters, each transmitting each 10 minutes, won't cause any stronger RF energy background than the radio broadcasting and mainly the GSM/3G/4G/... networks.
