Author Topic: Glow discharge that strikes inside the outer of my Osram HQI-TS 70W/WDL?  (Read 1054 times)
Glow discharge that strikes inside the outer of my Osram HQI-TS 70W/WDL? « on: February 12, 2017, 07:38:49 AM » Author: dor123
When I hot restrikes my Osram HQI-TS 70W/WDL Excellence in my tracklight, there is a glow discharge that strikes inside the outerbulb .
This was happened also when the lamp was used for the first time.
The lamp made in Germany.
Why this is happening?
« Last Edit: February 12, 2017, 07:41:19 AM by dor123 » Logged
Re: Glow discharge that strikes inside the outer of my Osram HQI-TS 70W/WDL? « Reply #1 on: February 12, 2017, 09:02:52 AM » Author: dor123
If the glow discharge is intentional for producting UV radiation to assist striking the arctube, so why my lamp don't start at all when there is a complete darkness in my room?
Also: Why during the hot restrike, I see the usual corona discharge and not a lighted strip like the one observed with high xenon pressure HPS lamps with integrated starting strips during their hot restrike?
« Last Edit: February 12, 2017, 10:04:22 AM by dor123 » Logged
Re: Glow discharge that strikes inside the outer of my Osram HQI-TS 70W/WDL? « Reply #2 on: February 12, 2017, 05:06:00 PM » Author: Ash
Because the discharge in the outer by itself might depend on the photoelectric effect.... Wonder how is that supposed to be sorted out ? Is it assumed that standard ignition voltage is sufficient to pull out Electrons there by electrical forces alone ?
The discharge in the outer must also not interfer with the discharge in the burner (so for example not clamp ignition pulses intended for the burner). Is it somehow a discharge which can limit its own current ? What would happen if a discharge lamp with same atmosphere (as the outer of the HID, but without option of striking inside the arctube) would be connected to HV, unlimited current source ?
