Heat shrink tubing for those wires will work wonders, if your not going to replace them, try and get the stuff with adhesive inside it, and if your not sure if they are asbestos or not, assume the worst and treat them like they are asbestos, keep the dust to a minimum and wear an N95 or better respiratory protection and disposable nitrile gloves, wash it all with clean water and your tools that you used, do this outside, and I would recommend using a pair of old clothes and toss them once your done, (don't wash them and contaminate your washing machine, used coveralls are cheap or those tyvek single use one, even if you look goofy in them, they aren't that bad and you only have to wear it for a short period of time) And if your replacing them keep everything damp that your working on, water won't hurt it so long as you let it dry completely before powering it up.. And yes people might think this is overkill, but it's better then getting killed by asbestos..
And for gaskets if you want ones that last forever, get a wood stove gasket they are cheap you glue them down with waterglass ( sold in the same area) and it will take what ever UV you can shine at it, even a broken outer bulbs and a MV running till it goes EOL, the last one I bought cost me about $10 for 12 feet of it and the glue was only a few bucks and they come in a wide range of sizes and even hollow tubes which flatten out nicely, they are fiberglass so they won't rot, or melt, and you can cut them with a knife, and a word of warning about the glue, don't get it on the glass you'll never get it off..
