General => Off-Topic => Topic started by: CreeRSW207 on November 28, 2019, 06:10:14 PM
Title: Can I replace a regular switch with a fan switch?
Post by: CreeRSW207 on November 28, 2019, 06:10:14 PM
My ceiling fan has a normal switch wired to it I’m wondering if I can change the regular switch with the fan switch.
Title: Re: Can I replace a regular switch with a fan switch?
Post by: Cole D. on November 28, 2019, 06:22:37 PM
You can, you can put the pull chain switch on the fan on high speed, and then use the wall switch to change the speeds. That's how the ceiling fans in my house are set up.
Just don't use a dimmer switch with it, because it can cause damage to the motor.
Post by: CreeRSW207 on November 28, 2019, 06:58:24 PM
Would I be able to use a switch like this? (https://www.homedepot.com/p/Lutron-Skylark-Fan-Control-and-Light-Switch-Single-Pole-White-SFSQ-LFH-WH/100399014?mtc=Shopping-VF-F_Vendor-G-D27E-27_2_WIRING_DEVICES-Generic-NA-Feed-PLA-NA-NA-WIRING_DEVICES&cm_mmc=Shopping-VF-F_Vendor-G-D27E-27_2_WIRING_DEVICES-Generic-NA-Feed-PLA-NA-NA-WIRING_DEVICES-71700000033102358-58700003867202208-92700048704097655&gclsrc=aw.ds&&gclid=CjwKCAiA_f3uBRAmEiwAzPuaM0qc33WFnZDwF3XEHiUgvfBvflmcUcm_yTUXnRGY56loOo19Tup-DhoCKVEQAvD_BwE)
Post by: Cole D. on November 28, 2019, 07:49:33 PM
I have that same switch in my bedroom. Slider for the 3 speeds and off and then the switch for the light.
