Author Topic: Don't know the contents of your HID?  (Read 1669 times)
UVIR
mercury blue
+YiannisGalidakis giannakisgalidakis
Don't know the contents of your HID? « on: December 07, 2020, 01:05:44 AM » Author: UVIR
Run this code and find out, compared to your observable spectrum.
Some nifty emulation of the spectral distributions of many non-LED popular lamps, which allows for direct utility calculations based on many different parameters including chromaticity, space type, lifetime, occasion, application, cost and efficiency. 7 such parameters are used with constrained weight optimization to fish out some of the more popular lamp types used in many situations today:
https://ingalidakis.com/spectroscope/elements.html
Will be modified some time later to deal with LEDs. Based on elemental spectral data published by NIST.
All pictures therein were generated using this code.
If you have Maple and want to run the code that produces these and do some tests for your lamps, see:
https://www.mapleprimes.com/posts/213753-Light-Chroma--Lamp-Engineering-Applications
"Full-spectrum" index, based on Rensselaer Polytechnic Institute's metric.
Suggestions 4 Improvements/Errors @ followup, here.
Cheers,
Yiannis-UVIR :mv:
-- "Eventually, everything is understandable" --
Re: Don't know the contents of your HID? « Reply #1 on: December 08, 2020, 11:32:37 AM » Author: Mandolin Girl
That just went right over my head...  :(
UVIR
mercury blue
Re: Don't know the contents of your HID? « Reply #2 on: December 09, 2020, 11:56:28 AM » Author: UVIR
Please neither underestimate yourself nor overestimate the quoted article. It requires nothing more than Physics 101, if even that. As a lighting enthusiast, you should familiarize yourself with at least a couple of notions from therein, color, light and chromaticity notwithstanding. It does contain some advanced stuff which might prove to be useful, such as the so called "full-spectrum" index, but such are barely mentioned in the calculations and you don't really need it.
It is mostly concerned with utility of various lamp types, stuff any lighting enthusiast should be familiar with.
Cheers,
UVIR-Hg blue [email protected]  :mv:
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Don't know the contents of your HID? « Reply #3 on: December 09, 2020, 12:20:11 PM » Author: Binarix128
It also happens to me with some articles and replies. Sometimes a little simplification helps me understand it better.
Re: Don't know the contents of your HID? « Reply #4 on: December 09, 2020, 12:24:49 PM » Author: Mandolin Girl
Exactly, I don't have any fancy measuring equipment much beyond a multi meter.  :wndr:
I just like looking at the lights as they come on and change colour as the arc tube warms up.  8)
