Author Topic: Article about Laser trained to the light bulb filament from TGDaily.com  (Read 4498 times)
Article about Laser trained to the light bulb filament from TGDaily.com « on: June 01, 2009, 04:55:05 PM » Author: rjluna2
Check this article out from TG Daily website at http://www.tgdaily.com/content/view/42653/178/ .
Re: Article about Laser trained to the light bulb filament from TGDaily.com « Reply #1 on: June 01, 2009, 05:49:53 PM » Author: Medved
Any incandescent is possible to make twice as bright and 50percent more efficient then the original - good enough just to make a catching newspaper article.
Well, the lifetime would then a bit lower, but "It was first experiment, the technology will for sure be tuned by later development"...
And in meantime other similar "breaking discovery" appear, the former is somehow "forgotten" and the life goes on...
bluelights
Re: Article about Laser trained to the light bulb filament from TGDaily.com « Reply #2 on: June 02, 2009, 03:56:01 AM » Author: bluelights
Yes, the super-efficient incandescent bulbs are called halogen ;D
But nonetheless still an interesting article.
Save the mercury lamp
Silverliner
Rare white reflector
Re: Article about Laser trained to the light bulb filament from TGDaily.com « Reply #3 on: June 05, 2009, 05:58:02 PM » Author: Silverliner
Dunno if that's true, but it sounds like the laser treatment turns the filament into a lattice structure. Tungsten lattice had been experimented before, and they only last a short time before the pores melted and it becomes as efficient as the common incandescent bulb. When it comes to a balance of efficiency, life and durability, today's incandescents are pretty much the known upper limit. Halogens goes up to about 35-40 lumens per watt.
Member of L-G since 2005.
Electrician.
Re: Article about Laser trained to the light bulb filament from TGDaily.com « Reply #4 on: June 06, 2009, 12:40:01 AM » Author: Medved
35..40 was reached only by heat recycling (IR reflective coating), bare tungsten is at ~20lm/W max, assuming design for 1000hours at least.
