Author Topic: Why not electronic ballast for mercury vapor?  (Read 50013 times)
Re: Why not electronic ballast for mercury vapor? « Reply #15 on: April 03, 2025, 02:44:13 AM » Author: RRK
I bet the reason is mainly economical. There is no reason to hook a $5 lamp on $50 ballast. No problem to make a suitable electronic ballast. Either MH like bridge circuit less the ignitor, or HF sinewave ballast at ~150kHz, so well behind possible acoustic resonances and their main harmonics.
However as HPM lamps are out of favor and banned in many places, no one cares to design a new ballast any more. Also, electronic ballast seems still a bit less robust outdoors than magnetic gear. And one can make heavily cost-optimized choke with aluminium windings. Large and heavy, but cheap. Aluminium is cheap. Iron is cheap. No expensive copper. But extra weight does not matter much in an outdoor lantern. That's unlike rail-mounted shop lighting with CMH lamps where the weight and bulk is of course at premium and small electronic ballasts, even painfully expensive at their time, were preferred.
Re: Why not electronic ballast for mercury vapor? « Reply #16 on: April 03, 2025, 03:27:01 AM » Author: RRK
In theory it could be possible to make an HPMV lamp to run on electronic ballast but there is little point in lighting applications, because the luminous flux and efficacy both drop by a small amount.
The plasma temperature is increased on a high frequency ballast, which caused preferential ionisation of energy transitions that radiate in the UV wavelengths.  So UV-B output increased while visible decreases.  Electronic ballasts are therefore quite common for UV mercury lamps.
But probably a better red ratio from deluxe lamps then? May be quite pleasing!
UChBXesrxSalDTp79uMtfDvA
Re: Why not electronic ballast for mercury vapor? « Reply #17 on: April 03, 2025, 03:30:09 AM » Author: WorldwideHIDCollectorUSA
I am seeing evidence that Toshiba did make some electronic constant wattage mercury vapor ballasts for the Japanese market if you look at pages 1049 and 1050 of the 1992-1993 Toshiba catalog:
https://page3.cextension.jp/c1091/book/index.html#target/page_no=1084
Part numbers for these Toshiba constant wattage electronic mercury vapor ballasts include the following:
4HSE-201HW for 400W mercury vapor lamps
7HSE-201HW for 700W mercury vapor lamps
In that case, electronic mercury vapor ballasts DID EXIST, but were not very popular on a global scale. Additionally, there were also some mercury vapor security light fixtures sold in North America that also used electronic ballasts, but they were not popular as well.
« Last Edit: April 03, 2025, 03:56:46 AM by WorldwideHIDCollectorUSA » Logged
Re: Why not electronic ballast for mercury vapor? « Reply #18 on: April 03, 2025, 04:04:13 AM » Author: RRK
If you are talking about electronically ballasted yard blaster security light discussed here a few years ago, yes this circuit was somewhat extremely crappy and cost-cut...
Re: Why not electronic ballast for mercury vapor? « Reply #19 on: April 03, 2025, 04:07:39 AM » Author: WorldwideHIDCollectorUSA
I am probably thinking that the Toshiba electronic mercury vapor ballasts for Japanese 400W and 700W mercury vapor lamps would have probably been built more robustly than those low quality North American electronic security light ballasts. It would be nice if someone managed to find those ballasts as they are so unique to Japan.
Re: Why not electronic ballast for mercury vapor? « Reply #20 on: April 03, 2025, 06:51:19 AM » Author: Medved
According to the wiring diagram, these are not electronic ballasts, but electronic dimmers. It could be they are there to compensate for mains variation or so, but nothing more.
Re: Why not electronic ballast for mercury vapor? « Reply #21 on: April 03, 2025, 12:20:47 PM » Author: WorldwideHIDCollectorUSA
I do seem to see that they might be electronic ballasts whenever I take a screenshot of the catalog pages and run them through translation apps, but the translations might not always be accurate.
Re: Why not electronic ballast for mercury vapor? « Reply #22 on: September 29, 2025, 04:32:58 PM » Author: WorldwideHIDCollectorUSA
When taking another look at these ballasts, it looks to me that the ballast wiring diagram seems to show that they likely have an electronic control unit that possibly helps to regulate the lamp current over mains voltage variations as I see that the translations seem to show that they do function as a constant wattage ballast.
Re: Why not electronic ballast for mercury vapor? « Reply #23 on: October 05, 2025, 07:52:56 AM » Author: RRK
I was intrigued by this comment and did a little experiment, abusing one of my super deluxe mercury lamps.
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-261931
As a result I don't see a sign of increased UVB output and more red from the phosphor. Instead I see that the lamp runs with a little bit colder CCT 3387K on HF(46.5KHz) vs 3300K on 50Hz. Though, my experiment is not 100% clean as the lamp runs slightly overpowered on HF ballast, some spectral balance shift may be attributed to this.
Probably need to re-run this experiment with a ballast in 58W fluorescent mode, this time a current of ~0.48-0.49A will be a closer match to what the lamp expreiences on 50Hz (in fact a bit below of what IEC 188 prescribes!)
« Last Edit: October 05, 2025, 08:05:12 AM by RRK » Logged
Re: Why not electronic ballast for mercury vapor? « Reply #24 on: October 05, 2025, 01:20:18 PM » Author: RRK
Tried another ballast, at slightly lower current and at higher frequency. And indeed, arc instability shows up. So this is the answer to the initial question, why? Low frequency squarewave ballasts could be build, but this is probably too much fuss for low-cost mercury lamps, like it was said already before.
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-261943
Probably this instability can be thwarted by some electronic tricks like pseudorandom frequency modulation.
