Author Topic: Ken Rad f4t5 datecode  (Read 1510 times)
Bean
Ken Rad f4t5 datecode « on: March 18, 2022, 09:38:07 PM » Author: Bean
I know I've created a topic similar to this but this one will have more detail.
Since I got my Ken Rad f4t5/cw, I've been trying to find when it was made, while I believe it was made in the 1950's, that's not very clear. The bulb has similar construction to some Westinghouse bulbs and a Sylvania bulb I have in my collection.
I'm not 100% sure which brand made this bulb because it is super similar to a Sylvania bulb I have.
I looked at Westinghouse datecodes on Lamptech however they didn't seem to match the datecode on the lamp so I looked at Sylvania 1950's datecodes and it did produce a bit of a match. While I'm not sure if I'm looking at the etch and deciphering it correctly, the lamp was most likely made in 1957 because I read the 4 dots to the left of the USA on it and the lamp has an aluminum endcap (I think).
The month may be November or December because on the Ken and Rad there are two dots and a dash.
Does anyone have any other decipherings of the date code?
bulb_tester2009
Re: Ken Rad f4t5 datecode « Reply #1 on: May 30, 2022, 10:56:30 PM » Author: bulb_tester2009
Well, I think the point and date probably had nothing to do with it
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
由于我来自中国,所以英语不精通,大部分内容都是翻译的,所以可能不通顺,请大家谅解
Note:
Total number of currently updated EOL lamps in the Lighting-Gallery: 14
My total EOL lamps: 7
© 2005-2023 Lighting-Gallery.net | SMF 2.0.19 | SMF © 2021, Simple Machines | Terms and Policies
