Author Topic: Have you ever encountered a ballast explosion, smoke or other failures?  (Read 65537 times)
tigerelectronics
Long live fluorescent!
UCcObKY_XCMIZZOBNWn-PC4A
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #45 on: October 30, 2025, 03:52:42 PM » Author: tigerelectronics
Oh yes! I've had some very exciting failures for sure in my days! Ballasts overheating and catching fire due to severe EOL situations with severely elevated mains voltage, capacitor explosions, and other fun stuff!
I guess the most spectacular fail I've had in my own personal collection is 3 shorted Philips ballasts from 1958, the fluorescent tubes literally exploded, that was extremely impressive! But not in a good way....
Fluorescent tube hoarder :P
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #46 on: October 31, 2025, 10:27:37 AM » Author: HomeBrewLamps
Back when i was a child a capacitor failed on a ballast for a 250 watt mercury lamp and it smelled up the whole house.
Parents were not amused.
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #47 on: October 31, 2025, 02:03:59 PM » Author: Ash
Back when i was in high school a capacitor smoked up some offices with thick sticky smoke. People were looking into computers and network cabinets, completely ignoring the FL fitting on the ceiling from which smoke was visibly emerging
The capacitor was dry film type in plastic case, made in the 80s. lasted about 20 years. It was completely melted, when the janitor opened the fitting the melted plastic was stretching like chewing gum from the capacitor remains (still attached in the fitting on the ceiling) to the puddle of melted plastic that formed on the inside of the gear cover
The capacitor is wired straight across the 230V line for power factor correction, so it does not affect the operation of the lamps. Without it the 2x40W fitting pulls 0.86 line A, with it about 0.5A
In a later talk with the janitor (who worked here since the construction of the school) he told that exploding capacitors were a common occurence whenever lights were turned on back in the 1st year or so, and in many rooms he cut the capacitor out of the circuit, but not in those offices
I have since found many fittings in which the capacitors were melted in a similar way, the oldest from 1980 (as old as plastic film capacitors in plastic case go) and latest from 2010's
Vinnie12
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #48 on: August 06, 2026, 09:50:11 PM » Author: Vinnie12
Just a few days ago, my 125W MV ballast cooked itself, I intervened before it caught fire. I fired up my SON-H before shower, as I always do. When I got out, my room reeked of resin, I measured the ballast temps and it was 165 degrees C. Its rating is 120 degrees.
I also found that the bulb also separated from the base, RIP my Turnhout-made SON-H  :eoled:
Keep the meter spinning
Emersyn
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #49 on: August 06, 2026, 11:09:41 PM » Author: Emersyn
I've had ballasts get hot enough that you can smell them a bit, but that was with F18s on F15-20 ballasts since I didn't know you can't use them together. Luckily I caught it soon enough that there were no big issues.
lightsofpahrump
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #50 on: August 09, 2026, 10:58:20 AM » Author: lightsofpahrump
I've witnessed a fair few fluorescent ballasts go up in a BIG cloud of smoke ! Many years ago a classrooom in school had one release a big cloud of yellow smoke !  :DeAtH:   We left and finished class out in the courtyard !
  This one was well done when I bought the fixture : https://www.lighting-gallery.net/gallery/displayimage.php?album=5203&pos=82&pid=163404
YELLOW smoke?! How would THAT ever happen?
I like math, lighting, computers and electronics(but I detest pointless ruinage of nice old stuff). LEDs should be better thought out. they are actually quite good if they are good quality. They should be built to a long life not to a cheap price!
Freedom's not slavery, communism is!
tigerelectronics
Re: Have you ever encountered a ballast explosion, smoke or other failures? « Reply #51 on: August 18, 2026, 03:19:37 AM » Author: tigerelectronics
I saved a couple nice old industrial fixtures that were stored in a damp cellar at a factory. They survived amazingly well, I gave them a good wash and they came right back.
They're Järnkonst 3x65W, absolutely gorgeous. Date code 1972. They're by far some of the beefiest fixtures I own.
I powered them up with sacrificial test tubes and sure enough, all 3 tubes lit in both of them. I ran them for a couple hours happy as can be, I left the room for a bit to go do something else (it's in a outdoor building so im not afraid of leaving things running.) when I came back, the fixture felt noticeably brighter, I noticed one of the tubes had severe end blackening which it didn't have before. I suddenly noticed: just one fixture was suddenly pulling over 600 watts on my power Meter.
A few seconds later a hissing sound began, and smoke began literally pouring out of the fixture!
I quickly opened it up, to see something leaking out of one of the old Helvar ballasts. The square ones with two mounting plates. It was smoking and the paint melted off!
I've had bad luck with those in the past...
A couple weeks later. All 6 ballasts (3 in each fixture) went bad in the same way. I can only assume the insulation broke down from the moisture being stored in that damp location.
I replaced all ballasts with new VS ballasts, so the fixtures are once again happy. But yeah I'm thankful I didn't run any good tubes in it first because they did kill a few...
So be cautious of the 70's helvar ballasts with the two square mounting plates. I don't trust them.
