Author Topic: SBMV EOL  (Read 2481 times)
lightinggalleryuser33450
SBMV EOL « on: May 06, 2023, 10:15:12 AM » Author: lightinggalleryuser33450
What do SBMV lamps do when the incandescent filament fails? is the arc tube connected to mains voltage? does it just not work at all? or something else?
Re: SBMV EOL « Reply #1 on: May 06, 2023, 10:43:48 AM » Author: dor123
The lamp simply stop working, as the circuit inside the lamp going open. The ballasting filament acts also as an oxygen fuse, so when its burns out, the arctube being disconnected.
Re: SBMV EOL « Reply #2 on: May 06, 2023, 08:45:28 PM » Author: joseph_125
Yeah it just stops working as the filament is connected in series with the arctube so if the filament is broken there's no power going to the arctube.
There were some SBMV that used a halogen lamp in series with the arctube, those will still go out if the filament breaks, but the filament in those won't break if the outer is broken like on a standard SBMV though.
Re: SBMV EOL « Reply #3 on: May 06, 2023, 11:54:32 PM » Author: RRK
I believe another popular failure mode of SBMV is to go into cycling. Have seen a string of SBMV in cobraheads all go cycling. Can be explained as - 1. Thermal mode of SBMV is more problematic than a regular MV because filament generates additional heat especially when lamp run horizontal. 2. Resistive ballast does not generate voltage spikes at reignition, so discharge reestablishment on AC is trickier and even new lamps run with current pause - see an oscillogram.
Re: SBMV EOL « Reply #4 on: May 07, 2023, 04:36:00 AM » Author: dor123
@RRK: Cycling isn't a failure mechanism of SBMV lamps. It happens in low wattage SBMV lamps, when they are burning horizontally. Because of this, SBMV lamps shouldn't be burned horizontally but only vertically.
SBMV lamps with halogen lamps, will also fail when the filament in the halogen lamp break, but not if the outerbulb breaks, as the filament is protected from oxidization by the halogen capsule.
« Last Edit: May 07, 2023, 05:56:34 AM by dor123 » Logged
Re: SBMV EOL « Reply #5 on: May 07, 2023, 08:24:25 AM » Author: RRK
You are right here that you should not run SBMW lamp horizontally. In fact, they are usually specified 'vertical +-30 degrees' to 'vertical +-45 degrees' (for Osram HWL250). In the cobrahead lamp runs probably tilted more than 45 degrees from vertical, so that might be a reason they cycle. That was many years ago, those were neither Philips or Osram, probably early Electrofar Romanian ones. Good luck finding a datasheet for them.
Re: SBMV EOL « Reply #6 on: May 07, 2023, 08:26:31 AM » Author: dor123
In the cobraheads, the lamp runs horizontally.
« Last Edit: May 07, 2023, 09:09:10 AM by dor123 » Logged
