Author Topic: A US Philips ALTO F96T12 110W HO lamp wildly flickering on a rapidstart ballast  (Read 6142 times)
A US Philips ALTO F96T12 110W HO lamp wildly flickering on a rapidstart ballast « on: May 21, 2010, 06:07:59 AM » Author: dor123
http://picasaweb.google.com/110595932802324922410/Lighting?authkey=Gv1sRgCI6D9bav-ezxcQ#5473662444846250066
This lamp is found at a supermarket near Rosh Pina township.
This is not a smooth 50hz flicker. This is likely that the ballast trys to reignite the lamp to stablize it (EOL behavior).
As you can see, there is NO end blackening, so why it is behave like it's reaches EOL?
Note: The flickering was much more wildly in reality then in this video.
The ballast is Eltam's rapidstart magnetic ballast for 105W T12 lamps.
« Last Edit: May 21, 2010, 08:43:43 AM by dor123 » Logged
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: A US Philips ALTO F96T12 110W HO lamp wildly flickering on a rapidstart ballast « Reply #1 on: May 25, 2010, 07:12:31 PM » Author: Foxtronix
Early rectifying is possible, if one filament is dipped in too little emitter during manufacture.
