Author Topic: Is this lamp leaked? Philips C70S62/C/M from eBay  (Read 7560 times)
Maxim
Is this lamp leaked? Philips C70S62/C/M from eBay « on: August 19, 2025, 02:04:06 PM » Author: Maxim
Is my Philips lamp leaked?
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #1 on: August 19, 2025, 03:58:25 PM » Author: RRK
Why do you think so? Does it fail to ignite?
Al_M
GEC Z9464 90w SOX/LPS
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #2 on: August 19, 2025, 05:13:43 PM » Author: Al_M
Doesn't looked leaked to me.
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #3 on: August 19, 2025, 05:48:19 PM » Author: RRK
Probably Maxim means a funky looking blob of amalgam in the upper end of the tube?
Maxim
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #4 on: August 19, 2025, 06:00:22 PM » Author: Maxim
It has a delayed ignition time. And yes, I am referring to the sloppy blob of amalgam there. The lamp also takes quite long to warm up after striking... I know the fixture is good for sure.
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #5 on: August 19, 2025, 06:33:11 PM » Author: RRK
Give this lamp a few burn-in hours to stabilize before making any conclusion. Does it run-up to proper power and proper golden HPS color?
Maxim
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #6 on: August 19, 2025, 07:08:16 PM » Author: Maxim
It is very flickery / loud on initial startup, and for the first minute. Then it sits in a dim, though deep, orange glow. After about ten minutes, it flickers some more and finally transitions into its golden yellow, almost CMH-looking Comfort HPS color.
Multisubject
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #7 on: August 19, 2025, 07:36:25 PM » Author: Multisubject
I would think if it had leaked there would be some sort of visible sodium deposited on the outer envelope, appearing like a getter film. Maybe I am wrong though, I am no expert.
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #8 on: August 20, 2025, 03:20:17 AM » Author: RRK
SDW white SON are known to be somewhat hesitant to do glow-to-arc transition on start, and flicker a lot, due to their simplistic electrode structure. Run-up time is long. Likely this applies to HPS Comfort lamps too. In the end your lamp appears to have a proper color. White SON are very sensitive to even minor changes, so if something is even slightly off, you won't get the expected color.
« Last Edit: August 20, 2025, 03:23:18 AM by RRK » Logged
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #9 on: August 20, 2025, 12:27:45 PM » Author: Medved
I would guess the leaked sodium would react with the outer to form dark spot/haze, so I doubt it.
could be it got mechanically hit while running or hot, so the molten fill splashed on the arctube side. Question is, whether the electrodes got damaged or not.
But running it few hours will give some answer. The rectification could well be caused by the fill covering the electrode, so it would take some time of operation till it gets distilled back to the proper space so it won't interfere with the electrode anymore, even during the warmup.
Maxim
Re: Is this lamp leaked? Philips C70S62/C/M from eBay « Reply #10 on: August 20, 2025, 01:07:19 PM » Author: Maxim
@Medved , @RRK - thank you. I ran it for about 12 hours yesterday and it appears to start and run normally now. Also, the sodium splotch seems to have cleared up with use.
