Author Topic: Run-up time of American 1000-1500W probe-start MH lamps: Question  (Read 12796 times)
Run-up time of American 1000-1500W probe-start MH lamps: Question « on: August 31, 2025, 10:52:54 AM » Author: dor123
I've noticed that the American 1000-1500W probe-start MH lamps takes as long as LPS and medium pressure mercury lamps to run-up to full output. @Ne-guy M.CZ said me that his GE Multivapor 1000W probe-start MH lamp takes as long as 10 mins to reach full output.
On the other hands, European >1000W MH lamps, includes ones with starting electrodes like the Osram HQI-T 2000W/D/I and 2000W/N/I, takes much shorter time to run up to full output.
What is the reason for this?
UChBXesrxSalDTp79uMtfDvA
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #1 on: August 31, 2025, 07:11:40 PM » Author: WorldwideHIDCollectorUSA
I think the reason for this is because most North American 1000W M47 probe start metal halide lamps and 1500W M48 probe start metal halide lamps are usually operated on CWA ballasts while European HID lamps are almost always used on reactor ballasts.
I say this because I have observed that lamps operated on HX and reactor ballasts tend to warm up faster than lamps operated on CWA ballasts.
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #2 on: September 01, 2025, 06:01:28 AM » Author: dor123
I don't think the use of CWA or reactor should affect the warm-up period.
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #3 on: September 01, 2025, 06:21:06 AM » Author: Medved
It does and a lot.
CWA is a constant current, so when the lamp is still cold and its arc voltage low, the power dissipated in the lamp, so the heat warming it up, becomes low as well.
On the other hand the series reactor and to some extend also HX autotransformer tend to operate very close to saturation during normal operation (to minimize the number of turns needed, so the wire length and so losses).
This has the consequence of becoming partially saturated once the arc voltage is still low. And a saturated choke (or shunt in CWA) means the current becomes significantly higher than would otherwise correspond to the reactance it has at normal operation.
And this higher current at low arc voltages means higher power dissipated in the lamp, so more heat warming the thing up, hence the shorter warmup time.
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #4 on: September 01, 2025, 08:32:49 AM » Author: dor123
@WorldwideHIDCollectorUSA: Can you compare the run up of your 1000W probe-start MH lamps on an M47 ANSI ballast and on an H47 HX ballast + Philips SI-52 ignitor.
« Last Edit: September 01, 2025, 08:57:56 AM by dor123 » Logged
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #5 on: September 01, 2025, 02:27:26 PM » Author: WorldwideHIDCollectorUSA
I might give that a try if I find a 480V 1000W H36 mercury vapor reactor ballast and a suitable step up transformer and also a proper 1000W M47 probe start metal halide CWA ballast.
I have read that some catalogs suggest that North American 1000W M47 probe start metal halide lamps can run satisfactorily on 1000W H36 mercury vapor reactor ballasts rated at 480V or very rare 1000W H36 mercury vapor HX ballasts with an OCV of at least 440V or higher if the ambient temperature is roughly 50 degrees fahrenheit or higher.
So far, I once did have a 1000W M47 probe start metal halide lamp in my collection, but it sadly broke.
« Last Edit: September 01, 2025, 02:37:59 PM by WorldwideHIDCollectorUSA » Logged
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #6 on: September 01, 2025, 10:49:40 PM » Author: RRK
One thing to consider is American NaSc lamps have very oldschool pinch-sealed burners with some extra quartz mass while European burners are sleeker and probably smaller and highly power loaded, typically filled with rare earth chemistry.
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #7 on: September 03, 2025, 01:49:18 AM » Author: WorldwideHIDCollectorUSA
I have noticed that some European rare earth metal halide lamps tend to produce very beautiful colors during warmup.
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #8 on: September 03, 2025, 02:13:15 PM » Author: RRK
Colored metal halides are the best for the light show on run-up. Especially something Indium-Sodium-Lithium like this lamp!
hotrestrike
Re: Run-up time of American 1000-1500W probe-start MH lamps: Question « Reply #9 on: September 13, 2025, 01:44:14 AM » Author: hotrestrike
Run up of my 175w probe start Metalarc on a CWA ballast is in the same range as the 1000w-1500w sports lighters....it's pretty long and drawn out. Conversely, a Philips All-Start pulse start ceramic metal halide lamp on the same ballast runs up a bit faster, though still fairly long.
A 70w Philips CMH runs up quite a bit faster than a Sylvania pulse start quartz lamp with pinch seals on an HX ballast, and a Venture spherical arc tube quartz lamp is maybe only a little faster than the Sylvania. All are faster than probe start halide on CWA.
