Author Topic: CNC Machining Question  (Read 16867 times)
NeXe Lights
CNC Machining Question « on: September 29, 2025, 09:54:21 PM » Author: NeXe Lights
So, I've decided to design a mounting bracket for a 1000W ballast I ordered for my Kim EKG. What advice do you guys have? What material and thickness should I should use? Currently, I am set on using 1/8 inch (3.175mm) 5052 aluminum.
Multisubject
Re: CNC Machining Question « Reply #1 on: September 29, 2025, 09:59:40 PM » Author: Multisubject
By "mounting bracket" what do you mean exactly? Do you mean just some pieces of metal to secure the ballast to something? Or something more complicated
NeXe Lights
Re: CNC Machining Question « Reply #2 on: September 29, 2025, 10:22:06 PM » Author: NeXe Lights
I hope these images help explain what I mean.
Multisubject
Re: CNC Machining Question « Reply #3 on: September 29, 2025, 10:26:04 PM » Author: Multisubject
Ahh I see. So essentially a big plate to mount things on. I think 1/8" aluminum should do just fine, but it might be cheaper to use thinner steel. Are you making it yourself or having it made for you by a service?
NeXe Lights
Re: CNC Machining Question « Reply #4 on: September 30, 2025, 07:07:28 AM » Author: NeXe Lights
I am having it made by a service. I would prefer to use thinner steel since it's cheaper, but it rusts, which is a big no for me.
« Last Edit: September 30, 2025, 07:32:26 AM by NeXe Lights » Logged
Multisubject
Re: CNC Machining Question « Reply #5 on: September 30, 2025, 08:58:37 AM » Author: Multisubject
Oh I see, that makes sense. I think this is a pretty good plan.
Re: CNC Machining Question « Reply #6 on: September 30, 2025, 12:29:12 PM » Author: Ash
Zinc plated steel won't rust, and won't cause galvanic corrosion of the ballast where they come in contact with each other. But is more likely to hum when powered up (probably very soft and quiet hum for a thick plate)
If the environment this is used in is likely to corrode anything, i would be concerned for the ballast itself
