September 30, 2026, 09:00:16 AM
General
General Discussion
Lowest Voltage Fill Gas?
Topic: Lowest Voltage Fill Gas? (Read 2051 times)
Multisubject
« on: October 13, 2025, 05:35:06 PM »
Multisubject
Something called a "Penning Mix" of 99.75% Ne and .25% Ar is the lowest voltage mix of Ar and Ne, but are there any other gases that can lower this? I know Kr is used in high efficiency T8 fluorescent tubes, but how does that compare to Penning mix?
What is the gas/mixture of gases with the absolute lowest possible voltage drop?
Public Lamp Spec Sheet
More Info
Re: Lowest Voltage Fill Gas?
« Reply #1 on: October 13, 2025, 05:59:22 PM »
Voltage drop or ignition voltage?
These are different parameters and are not immediately related.
Xenon is usually associated with the lowest voltage drop in the discharge column, but Xe-filled lamps do not necessary have the lowest ignition voltage.
Multisubject
« Reply #2 on: October 13, 2025, 06:05:25 PM »
Multisubject
I am mainly talking about voltage drop while running, not ignition voltage.
More Info
« Reply #3 on: October 13, 2025, 06:19:14 PM »
So Penning mixes are not relevant here. Xenon (and mercury vapor BTW) are your friends
