Author Topic: Why do cars use either high or low beams?  (Read 6437 times)
Lcubed3
MAXIMUM LUMENS!!!
Why do cars use either high or low beams? « on: November 04, 2025, 11:52:31 PM » Author: Lcubed3
I have two trucks with sealed beam headlights and both of them use either the high or low beams, never both. If I modified them to use both, would anything break?
Portland General Electric: 120/240VAC @ 60Hz
Bringer of Light
Re: Why do cars use either high or low beams? « Reply #1 on: November 05, 2025, 12:57:37 AM » Author: Medved
Not good idea at all...
The headlight assembly is limited by its design on how much heat it can handle to the power of the one single filament at a time. So by powering both at the same time you get almost double the heat power the thing is designed for, so it will be overheating, damaging not only the bulb itself (the seals and the internal bulb, as I'm guessing it is a halogen, will be exposed to higher temperatures than designed for), but also its holder and the things around.
It may not be immediate damage, but over time it may lead to plastic parts becoming way too brittle and fall apart, paint pealing of the metal and the metal then corroding, sockets and wire insulation becoming brittle, crumbling away and leading to wires becoming bare and prone to short circuits and corrosion...
Cars which use separate headlamp for low and separate for high beam (like the ones using H7 or so) usually keep the low beam ON when the high beam is turned ON, the high beam optics is then designed to complement the low beam, so to throw the light only where the low beam is dark, so reaching higher total light levels. But these cars are designed with this, so the temperature management design of the headlamp assemblies includes this operation.
The combined headlights, like dual filament sealed beam or H4 can not handle the heat and need the low beam to be shut down when the High beam is turned ON.
Only the "warning flash" (aka "light horn") function (when you flash the high beam by pulling the control stick) allows to turn ON both at the same time, but then it is expected to last for just few seconds, so not enough time for the thing to warm up above the design temperatures.
« Last Edit: November 05, 2025, 05:49:02 AM by Medved » Logged
Re: Why do cars use either high or low beams? « Reply #2 on: November 05, 2025, 06:57:58 AM » Author: Ash
to add to the above
My car uses the same setup with H4 lamps (fairly standard in European cars)
When i am in low beam and suddenly do need the extra light (when i see in the dark in the distance something that might be obstruction on the road) i just hold the handle in the "flash" position untill i pass the place of question (just before the point where it clicks to the "high" position and turns the low beams off). The 10 or 20 seconds won't do anything
If held in this position permanently, for one this would probably melt the headlight reflectors, which in most modern cars are made of nickel plated plastic. In some cars it melts already with the normal setup. (Once it started melting, the plating cracks and bad spot starts absorbing more IR and will keep melting)
Re: Why do cars use either high or low beams? « Reply #3 on: November 05, 2025, 08:21:37 AM » Author: AngryHorse
High beam for cars should be banned!, it’s just allows people to drive faster at night! 🤨
Re: Why do cars use either high or low beams? « Reply #4 on: November 06, 2025, 12:20:38 AM » Author: HomeBrewLamps
My truck uses separated HB3 And HB4 lamps for highs and lows. So I could theoretically get away with modding the wiring to run all 4 with highs. which I have already done once. I found that the low beams being on cast too much foreground light which limited long distance viewing. So I reversed the modification and decided to add auxiliary high beam lamps instead. currently I am running 70 watt low beams, 50 watt fog lights, 100 watt high beams, and 100 watt air plane landing lights. 400 watts of high beam is plenty. however I have 250 watt aircraft lights I am planning on implementing. not because I need them. but because I have a crate of 24 I got for cheap. I cannot get a pair of 100 watt lamps for less than 40 bucks.
Re: Why do cars use either high or low beams? « Reply #5 on: November 06, 2025, 02:34:10 AM » Author: Ash
As long as there are no plastic parts or some small enclosed space inside the engine bay subjected to the heat of both lamps at the same time, there is no thermal problem
Next question is there an electrical problem ? Such as a shared wire providing either + or - to both the high and low circuits (this may be either from fuse to lamp, fuse to relays, relays to ground or anything else) ?
In this case you will have to separate one of the beams wiring completely to a new circuit, with new wiring all the way, new fuse (separate wiring and fuses for right and left beams if there is a condition when you drive and this is the only light on), new set of relays controlled from the original circuit
BTW, something i have seen (at least in a 90s Jap car where i fixed a problem with that) The gauge of the wiring used for the headlight circuits is thin enough to affect the brightness. After rewiring it direct from the battery (separate fuses and wires for right and left, 4 relays) with 4mm2 (approx 12#) the lights were noticably brighter and whiter light
Re: Why do cars use either high or low beams? « Reply #6 on: November 06, 2025, 03:45:36 AM » Author: Medved
Assuming there is no heat problem, you need to check the electrical power budget in the car. Don't forget the alternator is able to deliver half of its rating on engine idle and that should still be able to cover the steady loads (lighting, engine run and the related pumps, all the blowers,...), otherwise you will kill the battery in a short time...
Re: Why do cars use either high or low beams? « Reply #7 on: November 12, 2025, 06:31:44 PM » Author: wide-lite 1000
 There is/was a kit available for General Motors trucks which allowed for both low beams and high beams to be on at the same time . I've also seen that cars with Xenon headlights don't turn off the low beam when the highs are turned on  .
 Awhile ago , Ford sent us a mandate that we weren't allowed to operate the headlight flasher function on our ambulances when the headlights are on . We just programmed our system to cancel the headlight flasher when the headlights are on . Apparently , Ford was having issues with emergency vehicles melting both the wiring and the headlight housings because of this .
Re: Why do cars use either high or low beams? « Reply #8 on: November 12, 2025, 06:41:21 PM » Author: Ash
Is the headlight flashing for long enough for this to be an issue ?
Re: Why do cars use either high or low beams? « Reply #9 on: November 12, 2025, 06:49:00 PM » Author: wide-lite 1000
 Apparently . Depending on how the customer has us program their particular ambulance , I have seen some where the headlight flasher will function not only in "Primary" ( Vehicle in gear , engine running ) but also in "Secondary" (vehicle in park , engine running )  During a major incident , the truck may be sitting on scene for hours with the lights on .
Re: Why do cars use either high or low beams? « Reply #10 on: November 12, 2025, 06:57:32 PM » Author: Ash
I have never seen an ambulance flash its siren-flash with the headlights, it's always been a separate unit (beacon+siren combined unit or separate strobe units)
I can imagine driving with the headlights flickering all the time between high and low beam would be a major distraction to everyone, and blinding to other drivers on the road..
So i assumed it is some sort of manual "give way" signal (similar to the "quack" sound of the siren) that only sees short use
Re: Why do cars use either high or low beams? « Reply #11 on: November 12, 2025, 08:15:03 PM » Author: wide-lite 1000
 In the U.S. , ambulance specs/laws vary from state to state and city to city .  :police:
