Walter Knox
I apologize if this is a dumb question, but I know next to nothing about HID, I am more of a fluorescent guy. I am in the process of building a new shop, and I got a 1970s Norelco 175 watt mercury vapor fixture to put up on it. I expected it to come with a phosphor coated bulb, so i bought a clear one as well because I wanted the sickly green color that MV puts off. Well, to my surprise the fixture came with a clear bulb, but when fired up it just puts off a cool white color. No biggie, I bought another one as well. I get that one, and it does more of the same. Am I missing something here? These say nothing about color tone, I thought the clear ones were the ones which put off that sickly pale green color? Here is the one I got for reference (probably not the best quality I am sure, but I wanted something not vintage bulb wise as I plan to run it regularly, so i want easily replaceable and inexpensive.): https://www.ebay.com/itm/361732412500?var=631036867235
Multisubject
| The lamp you installed could be of a lower wattage than what the fixture is rated for, making it more white. But generally MV is a lot more white in person than it is on camera. I was also surprised with my clear MV at how unimpressively colored it was.
| If you judged mercury lamp color only by photos previously, cameras (electronic and film) typically render mercury arcs greener that they are to the eye due to metamerism.
BTW a true intense green lamp is green metal halide. You may wish to pick one!
Walter Knox
| Yeah, it is the correct wattage lamp; one of them is the one which came with the fixture from factory which was NOS. I could have sworn I remember a specific street light at the end of my grandparent's neighborhood which was pretty green, not green green like pictures show, but a very pale green color. These have none of that, they just look like a daylight lamp color tone.
Walter Knox
| I could also just be remembering it that way based on pictures I saw later on though, so that is a possibility I suppose. Either way, I guess I will install the fixture on the shop.
| Also, your lamp example on Ebay looks just slightly used. Heavily used/sputtered lamps, especially the ones behind plastic diffusers also heavily aged and yellowed, definitely look yellow-green to my eyes!
Walter Knox
| That lamp in the picture is definitely used right? I don't know why they would use that as their picture, the lamps are the same ones, but they are (the one I got at least) new in box and not used.
| I'd say this lot is a bit dodgy. Seller describes his lamps as brand new, but by the look this is just untrue. Lamps are not at the end of life, but are definitely somewhat used.
Lcubed3
MAXIMUM LUMENS!!!
This is almost exactly what it should look like: https://www.lighting-gallery.net/gallery/displayimage.php?album=7562&pos=1&pid=249898That's a 400w one caught using a film camera. I corrected it to look like real life.
Portland General Electric: 120/240VAC @ 60Hz Bringer of Light
Laurens
| The white-ish light from an uncoated lamp does not look green. It looks a blueish white to most people. But then you let someone look at their hands - zombie colors. It's one demo i do at work at talks about lamps and color rendering.
| Yes, it’s more of a cyan colour 😎
Welcom to OBLIVION ! B+M INTAMIN Gerstlauer GCI Longest serving LED at home: 64,694 hrs @ 14/6/26
xelareverse
| When clear mercury vapor lamps are new, they tend to be a little bit bluer, once you use it for a little while it'll shift more green. As others have mentioned, there is some blackening at the ends of the arc tubes in that photo, but that can also occur if the lamp is switched on momentarily and immediately shut off, for example if the seller wanted to test it. If you let it warm up and the arc tube goes clear once extinguished, you'll know that it's new. But definitely use it for a little bit, it will turn green after a while.
BT25
Vintage HID Collector
@Walter Knox - You've got to age that clear lamp like cheese for it to create a greenish light like gorgonzola!
Maxim
@Walter Knox — if you would like, I can send you a period-correct H39KB-175 made by Westinghouse, Philips-Westinghouse, or Philips. Let me know, it's yours for the cost of shipping.
hotrestrike
| One of the issues is also that those Caster lamps on eBay have undersized arc tubes so they will work better on the post-2000's generation of low-quality yard lights that underdrive lamps somewhat, but on an older, better quality fixture such as your Norelco, they will be overdriven and thus burn whiter than a vintage lamp would in the same fixture. You will also get drastically shorter life (in short - Caster lamps are poor quality). So, if you are planning to use the fixture more than just for display purposes and want a clear lamp, I'd absolutely recommend investing in a good quality, new old stock lamp. Or even a good quality used lamp i.e Philips, Westinghouse, Sylvania or EYE that was made at least a couple decades ago so take Maxim up on his offer!
