Author Topic: Cursed "homemade" E27 lampholders  (Read 16605 times)
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Cursed "homemade" E27 lampholders « on: December 17, 2025, 05:49:33 AM » Author: LightsAreBright27
https://youtube.com/shorts/ruygyDt8Wks
They use screws and bare copper wite to make an e27 base. The holders look so goofy and are probably dangerous  :DeAtH:
I dont understand the language, but translating it says " it's just a 5w lamp, there's no issue"
245v 50Hz
bydgoszczanin13
Aleksander L.
Re: Cursed "homemade" E27 lampholders « Reply #1 on: December 17, 2025, 08:09:09 AM » Author: bydgoszczanin13
It's not about the wattage, but the voltage, which is probably 230. Wrong side of your hand and your electrocuted :DeAtH:
Though the idea wasn't quite a bad idea, though it is dangerous with bare metal.
yes...
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Cursed "homemade" E27 lampholders « Reply #2 on: December 17, 2025, 09:56:49 AM » Author: LightsAreBright27
But the thing is no one is that desperate for an E27 holder, proper holders aren't that expensive. A plastic one is about half a dollar and a ceramic one is two dollars
245v 50Hz
Re: Cursed "homemade" E27 lampholders « Reply #3 on: December 17, 2025, 10:11:49 AM » Author: AngryHorse
I think that is quite innovative 😃, and in places like some parts of India, where you probably can’t just go out and buy a lamp holder it’s probably the next best thing!
Yeah it’s dangerous, but they probably don’t have a wiring code or a BS 7671 like western countries have?
Not a fan of the screws as the wood could get damp?, but the wire thing is quite genius thinking 🤔
« Last Edit: December 17, 2025, 10:14:04 AM by AngryHorse » Logged
Multisubject
Re: Cursed "homemade" E27 lampholders « Reply #4 on: December 17, 2025, 10:24:35 AM » Author: Multisubject
I have done something similar here, you gotta do what you gotta do!
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Cursed "homemade" E27 lampholders « Reply #5 on: December 17, 2025, 10:37:07 AM » Author: LightsAreBright27
I wonder if there's a version for B22 lamps, maybe 2 hook-shaped wires to hold the pins on the side and 2 screws for the contacts?
The E27 wire one would be safer if they put the top half of a plastic bottle on it
245v 50Hz
Re: Cursed "homemade" E27 lampholders « Reply #6 on: December 20, 2025, 02:48:13 PM » Author: Ash
The real danger here is fire
Wood is not a perfect insulator, it does pass some leakage current, initially tiny in the 100's uA range or less. The current breaks down the material and turns the wood into elemental carbon, slowly creating a carbon filament embedded within the thickness of the wood beam between the metal screws
As more wood is converted into carbon, the process accelerates. At some point it will abruptly turn into a runaway, with a glowing carbon filament igniting the wood from within
Additionally, this conversion to carbon removes any structural strength from the wood in the same way as rot does. It looks like they put those screws into a beam that is part of the house. This one does not seem structurally critical (it's not a huge beam, and there is no array of identical ones through the room), but if it's anything significant, something might come crashing down if the fire won't get it first
