Author Topic: PL-S lamp with starter, running on an electronic instant start ballast...?  (Read 2772 times)
suzukir122
suzukir123
PL-S lamp with starter, running on an electronic instant start ballast...? « on: February 24, 2026, 09:11:37 PM » Author: suzukir122
Okay, so the uploader of this video actually told me about the Ott-lite desk lamp that he has. Despite being electronic ballasted, it seemed to
operate the PL-S lamp with a starter, successfully, without any noticeable detrimental issues. Am I missing something?...
... unless maybe this desk lamp contains both an electronic ballast and magnetic ballast, which I highly doubt.
Anyways, here's the video: https://www.youtube.com/watch?v=eGQThMYJW14.
Interests:
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #1 on: February 24, 2026, 11:56:28 PM » Author: RRK
It is borderline okay, because usually a PL-S lamp has a capacitor inside (somewhere about 4700pf) *about* in the range of what to be expected for simple electronic ballast resonant capacitor. More, there are non-standard Asian 2-pin PL lamps containing a capacitor, but lacking a glowbottle inside.
« Last Edit: February 25, 2026, 02:29:58 AM by RRK » Logged
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #2 on: February 26, 2026, 11:21:20 AM » Author: Medved
The only problem with this is, the PL-S format does not specify the exact capacitor value or even its presence at all.
For magnetic the exact value does not matter and usually the starter works even with no capacitor, so some, mainly cheepeese, makers skipped the capacitor alltogether.
But the HF ballast needs the capacitor there unconditionally. It may be pretty tolerant towards its value, mainly when the glowbottle starter is present (it dictates the preheating current and OCV before the arc starts, but the glowbottle takes over the preheat when the capacitance is on the lower end), but if the capacitor is completely missing in some lamp, it won't work at all.
And because the standard does not strictly require the capacitor to be there, it needs to be formally restricted for systems where the missing capacitor won't matter, so to the mains frequency magnetic.
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #3 on: February 27, 2026, 03:41:06 AM » Author: LightsAreBright27
I did an experiment a while back, using a philips programmed start electronic ballast on pl-s 9w and 11w lamps. The ballast specified it can be used with those (out of 4 pins, only 2 should be connected). The lamps worked, and some even started with a starter 'ping' just like a magnetic ballast. I put an eol lamp, and it flickered as if it was on a magnetic ballast. After 10 seconds the ballast turned off (eol protection)
So an electronic ballast is able to run a standard pl-s lamp with a glow bottle starter.
245v 50Hz
suzukir122
suzukir123
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #4 on: February 27, 2026, 03:04:38 PM » Author: suzukir122
@LightsAreBright27, did your 9w and 11w PL-S lamps contain capacitors near the glow bottle? (Really interested in that 11w one as well, since
it appears we do not have 11w PL-S lamps here in the U.S.)
Also, when you say the EOL lamp flickered, do you mean flashed?
I would think that an EOL PL-S lamp, at least on a non EOL protected electronic ballast, would be extremely hard on the electronic ballast to
the point of ballast EOL.
... but what was the point of adding a capacitor near the glow switch bottle on PL-S lamps? I know now from you guys, @RRK and @Medved, that those
capacitors can enable use with certain electronic ballasts, but do they not help in terms of performance on the magnetic Preheat ballast?
Why add a capacitor for the starter based PL-S lamp if it's not required?
Interests:
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #5 on: February 27, 2026, 11:18:04 PM » Author: RRK
It is known literally for centuries (from the time of first Ruhmkorff coils in 1800's) that self-induction circuits containing a coil and a switch generally work better when some small capacitance added across the switch. Limiting a voltage rise speed by a capacitor reduces sparking at the contacts and makes more energy transferring to the useful load. This is also *one* of the reasons why a capacitor is always added across car ignition distributor primary contacts.
Also, a small capacitor across the tube somewhat reduces RF interference generated by the tube in lower frequency bands.
So far I have not met any integrated starter CFL lacking a capacitor, though pretty anything is possible with lesser Asian knock-offs.
« Last Edit: February 28, 2026, 12:55:30 AM by RRK » Logged
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: PL-S lamp with starter, running on an electronic instant start ballast...? « Reply #6 on: February 28, 2026, 12:18:25 AM » Author: LightsAreBright27
@suzukir122 yes, almost all the 9w and 11w PL-S lamps had both a glow bottle and a capacitor in parallel.
I tried using Philips and Osram PL-S 9W lamps (I don't know if they have capacitors or not) and both had the same result, flashing before turning on. I also tried an Osram 10w & 13w PL-C, and both flashed before firing up.
I also tried using a cheap PL-S 9W lamp without a glowbottle starter, just a capacitor. That lamp instantly fired up on the ballast, no flashing.
The eol lamp was flashing and I could hear a starter 'ping' sound every time it flashed. The ballast turns off after 10 seconds so it knows that the lamp is eol.
Also, is it the same reason that almost all starters for magnetic ballasts have a film capacitor (usually silver colored) in parallel with the glow bottle?
« Last Edit: February 28, 2026, 12:22:12 AM by LightsAreBright27 » Logged
245v 50Hz
