Author Topic: Unusual Lamps  (Read 18002 times)
FGS
Rory Mercury!
Unusual Lamps « on: January 18, 2007, 09:56:05 PM » Author: FGS
Did anyone encounter a lamp that eneaked past the quality check folks such as clear fluorescent when they should be coated?
dp
Re: Unusual Lamps « Reply #1 on: January 18, 2007, 10:27:03 PM » Author: dp
I encountered a SOX lamp that didn't have an arc tube. No prizes for guessing where it came from.
FGS
Rory Mercury!
Re: Unusual Lamps « Reply #2 on: January 19, 2007, 12:25:02 PM » Author: FGS
@Max - do you have a pic of it lit and unlit?
JECWhiz
Re: Unusual Lamps « Reply #3 on: January 19, 2007, 01:50:51 PM » Author: JECWhiz
you know....a lot of the current HPS lamps (except for GE brands) do not have the amalgam....and also they have been using xenon....more........some of my xenon filled HPS lamps would not fire up my old 1976 McGraw HPS fixture!!!!! It is because it requires higher ignitor starter power to fire it up and the older HPS didn't require that....
JECWhiz
Re: Unusual Lamps « Reply #4 on: January 19, 2007, 02:07:27 PM » Author: JECWhiz
I meant those lamps that still have sodium but mercury reduced or replaced by xenon as I was educated....also a lot of the newer HPS do not have amalgam....only the GE still uses them...
Hey Max...I also have a question...I was given a brand new HPS which was tried in a streetlight but was defected and they took it out as soon as it was put in.......
The problem was when I try it it only makes a "lighting shaped arc" inside the arc tube and the ignitor would keep triggering it and the HPS would not start up but making the lighting shaped arc.....what would be the problem??? (the HPS looks BRAND NEW)  I even tried the 5000 volts 30 ma transformer on the HPS and it made a clean purplish arc with an orange glow in the end...........I will post a pic if this bulb soon.....
Silverliner
Rare white reflector
Re: Unusual Lamps « Reply #5 on: January 19, 2007, 06:08:08 PM » Author: Silverliner
I have a Sylvania R-20 reflector lamp (R-63 in mm) where they forgot to coat the inside with aluminum coating. So it's just a reflector lamp with lightly frosted glass and no aluminum coating LOL.
Member of L-G since 2005.
Electrician.
Pippi
Pippi Longstocking - The world`s strongest girl
GoL UCpsE6sKyPz8uzLGMaVM92RA
Re: Unusual Lamps « Reply #6 on: May 21, 2007, 05:13:05 AM » Author: Pippi
Do you have any pictures of that lanp?
:bluecflhd: :yellowcflhd: :bluecflhd: :yellowcflhd:
dp
Re: Unusual Lamps « Reply #7 on: May 21, 2007, 09:06:42 AM » Author: dp
Nope, my workmate chucked it out.  :( :'(
jason_m
Re: Unusual Lamps « Reply #8 on: May 30, 2007, 09:19:28 PM » Author: jason_m
A Korean f8t5 fluorescent lamp etched warm white with daylight phosphor inside.
mr_big
Re: Unusual Lamps « Reply #9 on: May 30, 2007, 09:20:51 PM » Author: mr_big
Oops lol!  :D ;)
mr_big
Re: Unusual Lamps « Reply #10 on: May 31, 2007, 06:37:35 AM » Author: mr_big
I've seen one that was coated with phosphor on the outside and inside of the lamp
JECWhiz
Re: Unusual Lamps « Reply #11 on: May 31, 2007, 09:55:24 AM » Author: JECWhiz
Rudy...your confusing me... ???
mr_big
Re: Unusual Lamps « Reply #12 on: May 31, 2007, 09:58:24 AM » Author: mr_big
Oh I confused the seagull :P J/K
Here is what I meant it had a phosphor coating on the inside AND outside of the fluorescent tube
JECWhiz
Re: Unusual Lamps « Reply #13 on: May 31, 2007, 09:59:45 AM » Author: JECWhiz
still confusing!  :o
how is it possible to have phosphor on the outside of the lamp? it would just rub off!
mr_big
Re: Unusual Lamps « Reply #14 on: May 31, 2007, 10:00:57 AM » Author: mr_big
Well all the lamps in that case were in sleeves I pulled one out of the sleeve and it was covered with a thick layer of phosphor
