Author Topic: Idiots on TikTok  (Read 63025 times)
NeXe Lights
Idiots on TikTok « on: March 02, 2026, 04:51:11 PM » Author: NeXe Lights
https://www.tiktok.com/t/ZP8xaBesc/
99% of the people in the comments don't know a thing about fluorescent lighting.
Fluorescent lamps will only flicker when used on magnetic ballast, and almost all fluorescent fixtures that currently exist use electronic high frequency ballasts, no flicker will be caused.
Any UV created by the lamps would be blocked out by any plastic lens used, and in almost every example shown in the comments it is a fluorescent troffer with a plastic lens.
Many of these people also make the claim of high levels of blue light, any other efficient lighting technology would have the same problem without sacrificing efficiency.
Lastly, the claim that fluorescent lighting is too bright doesn't make much sense, if they got the place to switch to LED, it would be equally as bright if not brighter.
By the looks of it, most of these people straight up want to switch back to incandescent if not get rid of indoor lighting entirely. I'll stop my rant now.
« Last Edit: March 02, 2026, 04:58:51 PM by NeXe Lights » Logged
Re: Idiots on TikTok « Reply #1 on: March 02, 2026, 05:08:04 PM » Author: Ash
https://eco-story.com/uncategorized/led-outdoor-lighting-vs-metal-halide/
That's the sort of fraud which enabled LED to gain the popularity in the 1st place, during 15 years in which it was NOT the most efficient light source
If the same effort and resources would be put into traditional lighting, we might have had 200 Lm/W halides and 120 Lm/W Fluorescents by now
The page i linked is as old as the existence of Tiktok as whole, and is by far not the earliest example on the internet
Regarding Fluorescents and flicker - Yep, they do flicker, and even at 100Hz here
My workshop right now is lit up with 36W T8's and the outside has a 400W halide, all on magnetic gear, and you don't see the flicker at all because it is soft. You really have to set up a test to detect it
Nearly all LED high bay luminaires on the market have mad squarewave flicker that you immediately see with your eyes
NeXe Lights
Re: Idiots on TikTok « Reply #2 on: March 02, 2026, 05:20:45 PM » Author: NeXe Lights
That type of stuff really makes my blood boil. 3800 lumens out of 45W is pretty bad for LED by modern standards, but 3000 lumens out of a 150W metal halide bulb is just pure BS! That's practically the efficiency of a good halogen bulb, and very far from the actual efficiency of a 150W MH bulb.
« Last Edit: March 02, 2026, 06:22:07 PM by NeXe Lights » Logged
NeXe Lights
Re: Idiots on TikTok « Reply #3 on: March 02, 2026, 06:30:53 PM » Author: NeXe Lights
How do you think we would have been able to achieve 200 lm/W metal halide lamps? After all, that's about as good as a 131W SOX-E lamp today.
Econolite03
Matthew E.
Re: Idiots on TikTok « Reply #4 on: March 02, 2026, 11:42:21 PM » Author: Econolite03
TikTok is still brain rot. At my work we had some F32T8s on an electronic ballast get replaced with Ledvance selectable-color LED tubes, and unlike the old fluorescent tubes, these actually flicker to the point being nauseating. When a fan is on the desk you can see it as the blades spin on medium speed.
 :tfan:
All Hail the GE M-400
lightsofpahrump
Re: Idiots on TikTok « Reply #5 on: April 03, 2026, 11:28:58 AM » Author: lightsofpahrump
Although if we had focused on conventional lighting technologies we would not have the versatility of LED.Take a deformable garage light for example-the type that screws into a light socket. It would be *possible* to do that with fluorescent. But it would be a bit bulkier and somewhat dimmer. There are so many things that you can only really do with LED........but not all of them are only possible with it.
I like math, lighting, computers and electronics(but I detest pointless ruinage of nice old stuff). LEDs should be better thought out. they are actually quite good if they are good quality. They should be built to a long life not to a cheap price!
Freedom's not slavery, communism is!
Laurens
Re: Idiots on TikTok « Reply #6 on: April 03, 2026, 11:57:39 AM » Author: Laurens
Folks, do realize that not everything is about the efficiency. It's also about mercury content (10mg in each of a couple billion of discharge lamps used throughout the world adds up) and simply cost (LED stuff is a lot cheaper).
Doesn't mean there's not a ton of misinformation about lighting stuff, but i see that even here with people spreading misinformation about LED flicker.
Re: Idiots on TikTok « Reply #7 on: April 04, 2026, 04:13:30 PM » Author: RRK
LED stuff in fact is not cheaper. Regular halo fluorescent tube is next to nothing in material costs. Soft glass and halo phosphor are very cheap, so cheap that recycling is negatively efficient economically until sponsored by governments. Truth to be told, LED recycling is not economically efficient either ;)
Laurens
Re: Idiots on TikTok « Reply #8 on: April 05, 2026, 03:16:01 AM » Author: Laurens
I've never been able to buy €1 CFLs like i'm able to buy €1 LED lamps.
Re: Idiots on TikTok « Reply #9 on: April 05, 2026, 06:13:42 AM » Author: RRK
In fact I was able to pick some CFLs close to $1. But the comparison is not fair as electronics for CFLs is somewhat more complicated than LED supplies. For linear tubes, some still available are $1 new with warranty at retail, ~$2 remaining triphosphor stocks. Available T8 LED substitutions are generally 3-5 times more expensive.
Maxim
Boiler Up, Hammer Down!
Re: Idiots on TikTok « Reply #10 on: May 24, 2026, 10:27:27 PM » Author: Maxim
@Laurens , @RRK — CFLs can go for as little as 25 cents each here. NO ONE likes them in the States. There are either LED adopters or incandescent diehards. You could probably put 1000 CFLs for $10 and no one would show up to grab them.  :lol:
PlasmaAddict
@MernokiMegoldasok nagy.peter.01
Re: Idiots on TikTok « Reply #11 on: June 03, 2026, 03:06:08 PM » Author: PlasmaAddict
Those are probably the same type of people who don't know anything about the electromagnetic spectrum and claim that 5G will give us cancer. The only downside of 5G is that everyone, even those idiots on tiktok get super fast internet to spead the bs even faster than before.
Plasma, the 4th state of matter is the most beautiful form of lighting that ever existed.
Re: Idiots on TikTok « Reply #12 on: June 04, 2026, 12:54:13 AM » Author: HomeBrewLamps
give me the 1000 cfls.... I would prefer 1000 incans.... but 1000 cfl is fine too.
