Author Topic: Power Grooves Having Trouble Starting  (Read 13024 times)
Burrito
McGraw Edison Rotoshields
Re: Power Grooves Having Trouble Starting « Reply #15 on: May 17, 2026, 05:29:44 PM » Author: Burrito
I cut the wires too short to attach back on the HO ballast so I can't use it unfortunately
Going on 6 years and counting. RMS Titanic went down 114 years ago. Works at The Home Depot store # 4412 and proud of it!!!
Patrick
Webmaster
LightingGallery
Re: Power Grooves Having Trouble Starting « Reply #16 on: May 17, 2026, 06:27:16 PM » Author: Patrick
Do you have any spare wire around you can borrow, perhaps from a cheap ballast, extension cord, NM cable, etc.?  If I don't have 18 AWG I'll sometimes splice in either 14 AWG or 16 AWG in the middle, then back to 18 AWG at the sockets since most of them only accept 18 gauge.
Is it that you cut the leads back too far to ever re-use the ballast, even if you could the a hold of additional wire?  I've often stolen wire from one ballast in order to hook up another, but I try to leave enough to still reconnect it in the future.
« Last Edit: May 17, 2026, 06:35:48 PM by Patrick » Logged
Patrick C., Administrator
Burrito
Re: Power Grooves Having Trouble Starting « Reply #17 on: May 17, 2026, 09:32:10 PM » Author: Burrito
I cut the wires too close to the ballast case so it is unusable
Patrick
Webmaster
LightingGallery
Re: Power Grooves Having Trouble Starting « Reply #18 on: May 17, 2026, 11:05:50 PM » Author: Patrick
If there's enough to strip but not quite enough for a wire nut, maybe you could get a Wago or other push-in wire connector.
Even if the lamps lit on the HO, that wouldn't prove the VHO ballast was fault considering electronic ballasts tend to have more success starting faulty lamps.  However, if impurities or poor lamp conditioning is to blame, some run time on the electronic ballast might enable them to start on the magnetic ballast again.  If the problem is partial vacuum loss, then they'd likely degrade further and eventually fail to start on the HO electronic.  That'd be unfortunate, but at least you'd have your answer.
Provided the cathodes are being heated, there's probably no harm in letting them sit flickering for a while.  Perhaps they'll eventually fire up.  That being said, if one of the cathodes isn't being heated, the result will be irreversible sputtering.  Another option is to try the opposite and leave them off for a while.  I'm unsure why, but I've had some troublesome lamps in the past that seemed to become easier to start after being left off for a day or more, although I'm a little unsure why this is the case.
I presume this is a series ballast, right?  I wonder if there's another kind of lamp you could put in series with the PG temporarily to test them individually.  Perhaps somebody here would know what might be acceptable for a quick test.
Also, I know you've checked everything, but I would again inspect every lead wire from the ballast to the socket and also make sure the lamps are all snug.
Burrito
Re: Power Grooves Having Trouble Starting « Reply #19 on: May 18, 2026, 12:24:16 AM » Author: Burrito
I just wired the ballast for 1 lamp operation and the one tube works.
Re: Power Grooves Having Trouble Starting « Reply #20 on: May 18, 2026, 11:23:48 AM » Author: joseph_125
I'm assuming you shunted the ballast for single lamp operating...wiring the single lamp between the red and blue pairs on the ballast, which results in a increase of OCV for that single lamp as it doesn't need to strike two lamps at once. As for the HO ballast, unless you cut the wires right where it enters the case, you can probably still attach a WAGO inline connector to it, or splice and solder wire extensions to it.
Patrick
Webmaster
LightingGallery
Re: Power Grooves Having Trouble Starting « Reply #21 on: May 18, 2026, 12:10:16 PM » Author: Patrick
I presume using only one lamp will stress the ballast so it wouldn't be good to leave it in that state for any length of time, but did you check both tubes that way?  Although it won't prove what's wrong if either works independently, if the other one doesn't light that would suggest it's the problem.  If they do both work, then I'd try wiring it back up for two-lamp operation and seeing if they'll now start up together.
Burrito
Re: Power Grooves Having Trouble Starting « Reply #22 on: May 18, 2026, 01:20:46 PM » Author: Burrito
No, the ballast says it can do one lamp operation if you cap the yellow leads which I did in this case.
Burrito
Re: Power Grooves Having Trouble Starting « Reply #23 on: May 31, 2026, 02:17:50 AM » Author: Burrito
It is with small sadness, I announce the loss of one of my Power Groove bulbs. I now have a new tube in it's place but I am running it on my HO ballast.
« Last Edit: May 31, 2026, 11:30:33 PM by Patrick » Logged
Re: Power Grooves Having Trouble Starting « Reply #24 on: May 31, 2026, 11:28:11 AM » Author: joseph_125
Well that sucks, did it fail due to vacuum loss? Unfortunately some of the F48PGs have flaws in the glass that result in early failure. I'd personally recommend a HO ballast over a VHO ballast for the F48s anyway. If you can find a magnetic one that would be the best since those almost always have cathode heating. Some of the electronic HO ballasts designed for signs were instant start which would cause issues with reduced lamp life and sputtering due to the cathodes not being at correct operating temperature.
Burrito
Re: Power Grooves Having Trouble Starting « Reply #25 on: May 31, 2026, 02:59:30 PM » Author: Burrito
Joseph, I can not see your message. It keeps giving me a 500 server error.
Re: Power Grooves Having Trouble Starting « Reply #26 on: May 31, 2026, 04:29:30 PM » Author: joseph_125
Yeah, it seems to be a problem with the site, I had the same error when I replied to your topic this morning and I had to jump through hoops to reply.
Patrick
Webmaster
LightingGallery
Re: Power Grooves Having Trouble Starting « Reply #27 on: May 31, 2026, 11:31:58 PM » Author: Patrick
Something about the attachment was causing it to crash.  I downloaded it, re-saved it in GIMP, then re-attached it.
Burrito
Re: Power Grooves Having Trouble Starting « Reply #28 on: May 31, 2026, 11:33:28 PM » Author: Burrito
Huh, that's a bit odd. Thank you for fixing it though!
Burrito
Re: Power Grooves Having Trouble Starting « Reply #29 on: November 06, 2026, 09:21:32 PM » Author: Burrito
Reviving a dead thread but, I have purchased exactly two F96PG17/CW tubes and a less bulky VHO ballast. The original tube that was next to this dead F48 has been lit on a HO ballast since May and it is running fine still, though the HO ballast unfortunately decided to smoke out on me and trip its thermal protector so these are back on the VHO weatherproof ballast. No failures yet, though the tube that was bought initially has a neat wear mark starting to form and the other tube is still working. The tube I sent in the image a few months back is still with me, just dead.
Will the F96PG17 tubes lose vacuum if I run them? They appear to be 2010s or 2000s era PG tubes.
« Last Edit: November 06, 2026, 09:27:21 PM by Burrito » Logged
