Author Topic: How Bright Is This Lamp Really?  (Read 5716 times)
DidiusMalloricus
How Bright Is This Lamp Really? « on: June 14, 2026, 03:45:52 PM » Author: DidiusMalloricus
So, I have recently acquired this 2000W Quartz-Halogen Stage/Studio bulb, it uses a GY16 bi-pin base, runs at standard 120 volts and is said to give off an incredible 55000 lumens at a 3200K color temperature (meaning the filament itself is operating at 2926 degrees C.)
It's supposed to be used in those expensive high-end Fresnel lens reflectors.
The rated life is just 400 hours.
My question is, has anyone seen one of these in operation? How bright is a 55000lm incandescent lamp really?
If I were to fire it up in the center of my dorm room, would it act as small powerful space heater?
Re: How Bright Is This Lamp Really? « Reply #1 on: June 14, 2026, 08:36:51 PM » Author: sol
You will need more than the 15A circuits that are in your dorm room. For resistive loads, 15A circuits have a theoretical limit of 1875 watts. For more than a momentary use, you don’t want to exceed 80% of that. And yes, it would throw considerable heat all the while increasing the power bill.
SoxFtw
Re: How Bright Is This Lamp Really? « Reply #2 on: June 25, 2026, 09:11:33 AM » Author: SoxFtw
While I haven't exactly seen a full 2kW lamp in person, I have seen a 4*500W array which, well, it's certainly bright. The ones I'm familiar with are T3s, but yeah, it would definitely function as a space heater and a rather hot one at that. IMO 400 hours is a bit on the longer side but I may be wrong. For context, a standard 2700K 9W LED would give somewhere around 875lm.
PS. definitely don't fire it up in the center of your dorm room; other than possibly starting a fire, could cause photo-keratitis (halogens emit a decent amount of UVA/UVB/maybe UVC) if run unshielded which is a not a very fun thing to experience.
« Last Edit: June 25, 2026, 12:11:41 PM by SoxFtw » Logged
Survivor of photokeratitis :(
👉KeepAndroidOpen.org👈
Re: How Bright Is This Lamp Really? « Reply #3 on: June 25, 2026, 04:10:33 PM » Author: RRK
I am highly skeptical any practically relevant amount of UVC is radiated. Anyway, one will get a thermal burn before any chance of UVA/B reaction ;)
Re: How Bright Is This Lamp Really? « Reply #4 on: June 25, 2026, 04:31:55 PM » Author: RRK
Here is a nice tool at Hamamatsu to play with blackbody radiation spectrum https://www.hamamatsu.com/us/en/resources/interactive-tools/black-body-curves.html
So in practice, some UVC is radiated, but is very weak, power at 250nm is about 2.5 orders magnitude weaker than visible light spectral power at 550nm, and ~3 orders weaker than NIR at peak wavelength of circa 800mn.
SoxFtw
Re: How Bright Is This Lamp Really? « Reply #5 on: June 25, 2026, 04:53:00 PM » Author: SoxFtw
Interesting, thanks! I naturally assumed there would be some amount of UVC... but apparently not in a practical power; noted.
UChBXesrxSalDTp79uMtfDvA
Re: How Bright Is This Lamp Really? « Reply #6 on: June 25, 2026, 05:26:09 PM » Author: WorldwideHIDCollectorUSA
If your dorm room has access to 220V outlets, you probably could run this lamp off of a step down transformer as 220V circuits should have up to 3300W of power capacity at 15A.
