Author Topic: Looking for a F24T12 Florescent Ballast for a sign restoration  (Read 24881 times)
LightDragon
I'm a street light and traffic signal collector.
Ben Haskin UCbTtLdQTwm5XIjX_lG5qbqg PolarTheIceDragon
Looking for a F24T12 Florescent Ballast for a sign restoration « on: June 14, 2026, 04:43:41 PM » Author: LightDragon
I'm trying to restore a traffic signal that uses an illuminate left box on top. its design to run two f24t12 lamps. uniformity it was removed but now that I own it I want to put it back to florescent. does anyone have a ballast I can buy or a recommendation to where i can get one?
I love finding weird obscure stuff to document on my YouTube channel.
Burrito
McGraw Edison Rotoshields
Re: Looking for a F24T12 Florescent Ballast for a sign restoration « Reply #1 on: June 14, 2026, 11:59:21 PM » Author: Burrito
Are they slimline or High Output?
I've had success with an electronic F40T12 ballast to run slimline F24T12 tubes. You can come across these magnetic Keystone ballasts that can run F24T12/HO tubes on eBay.
Going on 6 years and counting. RMS Titanic went down 114 years ago. Works at The Home Depot store # 4412 and proud of it!!!
LightDragon
Re: Looking for a F24T12 Florescent Ballast for a sign restoration « Reply #2 on: June 26, 2026, 07:22:01 AM » Author: LightDragon
They're HO lamps. They have the ends on them that are designed to go in sign. Can I use just any f40t12 ballast for these?
Burrito
Re: Looking for a F24T12 Florescent Ballast for a sign restoration « Reply #3 on: June 26, 2026, 12:33:26 PM » Author: Burrito
You could but it will under drive the tubes.
UChBXesrxSalDTp79uMtfDvA
Re: Looking for a F24T12 Florescent Ballast for a sign restoration « Reply #4 on: July 21, 2026, 05:34:48 AM » Author: WorldwideHIDCollectorUSA
Here is a proper rapid start magnetic ballast that I found that should properly run a pair of F24T12 HO tubes:
https://ebay.io/m/GI90yK
Hope this helps.
Re: Looking for a F24T12 Florescent Ballast for a sign restoration « Reply #5 on: September 07, 2026, 11:49:28 PM » Author: joseph_125
Yeah a HO ballast would be the most authentic restoration for it. Depending on the space for the ballast you might have to go with a slim HO ballast to fit
