Author Topic: 100 watt powerball metal halide (or normal ceramic) in 3000-4000K  (Read 3129 times)
100 watt powerball metal halide (or normal ceramic) in 3000-4000K « on: September 24, 2026, 10:46:49 AM » Author: HomeBrewLamps
I would like a pair of these guys if possible. I have the 70 watt version but I need 100s for my application.
SoxFtw
Re: 100 watt powerball metal halide (or normal ceramic) in 3000-4000K « Reply #1 on: September 24, 2026, 01:48:18 PM » Author: SoxFtw
Here's some listings for reflector CMH lamps by philips, known by "MasterColor":
https://www.ebay.com/itm/267709830148
https://www.ebay.com/itm/297862565499
And one with a medium base, ED shape:
https://www.ebay.com/itm/168598174330
The CCT is unknown but for the PAR lamps it should be below 4200K.
« Last Edit: September 24, 2026, 01:50:39 PM by SoxFtw » Logged
Survivor of photokeratitis :(
👉KeepAndroidOpen.org👈
Re: 100 watt powerball metal halide (or normal ceramic) in 3000-4000K « Reply #2 on: September 25, 2026, 08:00:27 PM » Author: wide-lite 1000
 Here's 50 of them . Not cheap tho . https://www.ebay.com/itm/267705119317
 Single : https://www.ebay.com/itm/297449132230
 Single : https://www.ebay.com/itm/286589888781
BT25
Vintage HID Collector
Re: 100 watt powerball metal halide (or normal ceramic) in 3000-4000K « Reply #3 on: September 26, 2026, 09:25:56 PM » Author: BT25
@HomeBrewLamps - What base are you looking for?
HID - Lighting with personality.
Re: 100 watt powerball metal halide (or normal ceramic) in 3000-4000K « Reply #4 on: September 27, 2026, 03:24:20 PM » Author: HomeBrewLamps
@SoxFtw Noice! not terrible deals there
@wide-lite 1000 That case of 50 is actually CHEAP per lamp. 5.60ish per. If I could pawn off some to members here I would actually consider that.
@BT25 Medium base! I have a drop light I converted to halide that I use on work sites and would like higher efficiency and CRI. the drop light is rated 100 watt max so I cant convert it to 150 watt or 175 watt unfortunatelt otherwise I would!
