Author Topic: F8T5 Spec  (Read 851 times)
Re: F8T5 Spec « Reply #30 on: October 07, 2026, 12:42:43 AM » Author: Medved
@stillaintjeff24:
Since I was curious on this myself, I tried it tonight...see this image .
I thought you were connecting two F8 instead of a single F14...
Connecting 1 for one means you are forcing the ballast to operate nelow its rated minimum arc voltage, there the current may become higher...
LightBulbFun
Re: F8T5 Spec « Reply #31 on: October 07, 2026, 12:50:03 AM » Author: LightBulbFun
did you look up the upload? look at the ballast being used (in both this thread and the upload on the gallery)
its a series burning ballast
its rated for 1 F14T5 to 2 F35T5
2xF8T5 is (just slightly) more than 1xF14T5 so its not going to be a problem in that regard...
Re: F8T5 Spec « Reply #32 on: October 07, 2026, 02:14:53 AM » Author: Medved
That is what I'm responding to...
But the text on the ballast label is not readable, I assumed it is rated just for two lamps (shown on the wiring diagram).
So if the ballast is rated to run just a single F14, then it is indeed perfectly fine...
