Author Topic: Is there a technical reason why High Pressure Sodium lamps top out at 1000W?  (Read 145 times)
DidiusMalloricus
Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « on: October 14, 2026, 05:14:52 PM » Author: DidiusMalloricus
I have never seen HPS lamps over 1000W or 1100W at most.
Is there a technical limitation for this?
Imagine how bright a 2000W, or 3500W HPS would be...
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #1 on: October 14, 2026, 09:07:11 PM » Author: wide-lite 1000
  https://www.lighting-gallery.net/gallery/displayimage.php?album=4617&pos=41&pid=120872
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #2 on: October 14, 2026, 10:30:51 PM » Author: HomeBrewLamps
@wide-lite 1000 I need one of thoseso I can make a light bar for my truck.... to defeat all the dodge pickup drivers with LED "retrofits".....
DidiusMalloricus
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #3 on: Today at 12:47:42 AM » Author: DidiusMalloricus
My God... a 50.000W HPS... can't even fathom what 8 million lumens look like...
Laurens
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #4 on: Today at 03:24:52 AM » Author: Laurens
Sheeeeeeeesh. You could light the entirity of amsterdam on it and run it from the overhead tram wire!
Maybe put a tram car in series with it to ballast it.
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #5 on: Today at 03:52:13 AM » Author: dor123
But generally HPS lamps with wattage higher than 1000W were extremely rare, compared to MH lamps which were available up to 3500W, and for the entertainment industry even 18,000W.
SoxFtw
Re: Is there a technical reason why High Pressure Sodium lamps top out at 1000W? « Reply #6 on: Today at 04:07:22 AM » Author: SoxFtw
With Sylvania's BriteArc set of lamps, they use quartz and are medium-arc. Quartz is fine with most halides but is not compatible with sodium-mercury amalgam.
Here is a 1500W lamp, even higher than 1100W: https://www.1000bulbs.com/product/89389/SUN-901692.html
Survivor of photokeratitis :(
Keep Android Open!
