Author Topic: Yes, those purple streetlights are still around. Here's why  (Read 796 times)
Yes, those purple streetlights are still around. Here's why « on: October 15, 2026, 02:34:52 PM » Author: rjluna2
Here is an article I found at the website: Yes, those purple streetlights are still around. Here's why :P
BT25
Vintage HID Collector
Re: Yes, those purple streetlights are still around. Here's why « Reply #1 on: October 17, 2026, 10:06:15 AM » Author: BT25
Hopefully this article will shut the attention seeking conspiracy nuts down...but it probably wont.
Re: Yes, those purple streetlights are still around. Here's why « Reply #2 on: October 17, 2026, 10:26:23 AM » Author: rjluna2
:lol:
SoxFtw
Re: Yes, those purple streetlights are still around. Here's why « Reply #3 on: October 17, 2026, 10:35:40 AM » Author: SoxFtw
Quote from: the article above
If streetlights in your area are affected by this issue, contact your local authorities to report the problem.
Contact the very authorities that installed the now defective lamps, stating they... don't produce light? produce harmful UV? hurt your eyes?
I don't know how things work over there but as long as the fixture produces light without any strobing or such, I don't think you're in a great position to complain.
To be fair, would anything? "You cannot reason a person out of a position he did not reason himself into in the first place"
Survivor of photokeratitis :(
KeepAndroidOpen.org
SoxFtw
Re: Yes, those purple streetlights are still around. Here's why « Reply #4 on: October 17, 2026, 10:40:36 AM » Author: SoxFtw
I could imagine just one such fixture in an otherwise dark street causing a beautiful liminal look late at night, in the cool breeze, not another soul in sight...
Although I imagine this is something quite typical in less urban areas.
KeepAndroidOpen.org
Lightingguy1994
Re: Yes, those purple streetlights are still around. Here's why « Reply #5 on: October 17, 2026, 11:10:58 AM » Author: Lightingguy1994
I would imagine there to be some UVA in the spectrum of the LED if theyre emitting bluish violet, but no where near enough to harm anyone.
SoxFtw
Re: Yes, those purple streetlights are still around. Here's why « Reply #6 on: October 17, 2026, 11:42:25 AM » Author: SoxFtw
Yes if they're truly in the light violet range like the images show, it might be a worry; but there's most likely a plastic/glass cover for the light and it's high enough that the intensity of it is zero or very close to zero.
I'm mildly surprised it's using light closer to 400nm than 450nm.
KeepAndroidOpen.org
Maxim
Re: Yes, those purple streetlights are still around. Here's why « Reply #7 on: October 17, 2026, 04:47:11 PM » Author: Maxim
On my way back to college, I saw a Marriott property with 100% purple LEDs. Wonder what the guests think!
Laurens
Re: Yes, those purple streetlights are still around. Here's why « Reply #8 on: October 18, 2026, 03:35:24 AM » Author: Laurens
No, zero UV of any kind. LEDs don't work that way. They are 450nm blue diodes which are far removed from UVA. Having bits of phosphor cling on can make it appear purple.
SoxFtw
Re: Yes, those purple streetlights are still around. Here's why « Reply #9 on: October 18, 2026, 04:17:14 AM » Author: SoxFtw
Ideally:
  LED  +  phosphor  =  WHITE
Except in this case, with a defective phosphor:
  LED  +  phosphor  =  PURPLE
(not a perfect representation but you get the idea)
KeepAndroidOpen.org
Re: Yes, those purple streetlights are still around. Here's why « Reply #10 on: October 18, 2026, 09:47:46 AM » Author: rjluna2
Wow! :eoled:
NeXe Lights
Re: Yes, those purple streetlights are still around. Here's why « Reply #11 on: October 18, 2026, 01:14:27 PM » Author: NeXe Lights
One time, I drove by an area where the warehouse, adjacent strip mall, and all the roads leading up to and around l had very bright violet light. It was quite the sight to see!
Laurens
Re: Yes, those purple streetlights are still around. Here's why « Reply #12 on: October 19, 2026, 01:16:26 AM » Author: Laurens
Yeah, it looks pretty cool, even if it is close to being useless as actual street lighting. I wonder what it would look like if you'd add a bunch of LPS...
Lightingeye60
Re: Yes, those purple streetlights are still around. Here's why « Reply #13 on: October 19, 2026, 07:56:07 AM » Author: Lightingeye60
Yep. Acuity LED fixtures made between 2017 and 2019 had a quality control issue where the phosphors would fall off the diodes causing the light to be purple. Thousands of street lights are affected by this failure mode. More are turning purple now if 2017-2019 manufactured. I believe some of the 2020 and 2021 model years are also turning purple. I’ve seen purple lights numerous times. I’ve even seen entire roads lit pretty much only with them.
This applies to the AEL ATB0, ATB2, 247L, Lithonia LED parking lot fixtures, and even some wall pack models. Visionaire Lighting and King Luminaire had similar failure modes with some of their fixtures. Some of the Leoteks are also apparently turning purple. But, usually the purple ones are from Acuity.
