Author Topic: Did mercury vapor FCO fixtures not begin being made until the 90s?  (Read 286 times)
Lightingeye60
Did mercury vapor FCO fixtures not begin being made until the 90s? « on: October 19, 2026, 09:33:16 PM » Author: Lightingeye60
What I’ve noticed is that when FCO fixtures first came into the market in the 1970s and 80s, there were no mercury vapor or metal halide versions, only HPS. It seems that Mercury vapor FCO’s weren’t being made until the 90s. It seems to be very rare to find a vintage MV cobra that’s full cutoff, while newer ones are actually relatively common in certain cities (notably Charlotte, NC and certain parts of Maryland). Some parts of Rhode Island also used them. I’ve seen FCO 115’s, M250R2’s, M250A2’s, and even newer M400’s and 125’s in FCO with mercury vapor lamps, but never have I found a vintage FCO M400A or a model 13 in MV. Both AEL FCO’s and GE FCO’s only listed HPS in their spec sheets.
This is very interesting since usually HPS fixtures were installed later than MV ones, but exceptions seem to apply. Most older MV fixtures are the traditional drop lens style. Newer MV installations can be FCO or drop lens similar to the HPS ones.
Same goes for MH cobra heads (as a whole), MH cobra heads didn't become somewhat common until the 1990s. Metal halide cobra heads are actually quite common in South Carolina, certain parts of Texas, and in Cincinnati, OH. Older FCO cobra heads in MV seem rare all around. I’m wondering if the early Cooper fixtures like the OVM or OVS were made with FCO and MV. I can’t find any spec sheets for those so I don’t know what lamp types were available for those.
AgentHalogen_87
Long Live SOX!
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #1 on: October 28, 2026, 07:15:46 PM » Author: AgentHalogen_87
We had FCO lanterns in the 1950s with mercury and LPS in the UK. They were usually standard lanterns with 'aeroscreen' shields to prevent upward light, or modified bowls made of metal with just a clear panel underneath. 1960s and 70s saw purpose built FCO lanterns for LPS.
But FCO back then had a very specialised use. They were only really used by railway lines or airports, so they were very rarely seen. It was only when HPS lanterns came out in the 80s that they started having FCO optics as a common option, and the last generation of discharge lanterns in the early 2000s and LEDs after are when FCO became standard.
« Last Edit: October 28, 2026, 07:25:54 PM by AgentHalogen_87 » Logged
Silverliner
Rare white reflector
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #2 on: October 29, 2026, 09:23:27 AM » Author: Silverliner
The GE M150 100w and 175w MVs in Rhode Island were definitely 1980s. So FCO in MV existed then. Caltrans in the LA area also began using FCO replacements for MV freeway lighting in the late 80s. As late as 1987 they were still installing new MVs with glareshields.
Member of L-G since 2005.
Electrician.
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #3 on: October 29, 2026, 01:52:41 PM » Author: wide-lite 1000
 Just looked at a 1977 GE catalog which listed both the M-250 & M-400 as available in MV .
Econolite03
Matthew E.
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #4 on: October 29, 2026, 04:41:51 PM » Author: Econolite03
The first generation M-400A FCO (sealed optics) I know for sure was offered in MV.
All Hail the GE M-400
Lightingeye60
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #5 on: October 29, 2026, 09:39:48 PM » Author: Lightingeye60
I read their old early 80s and late 70s catalogs and it is listed but not their mid to late 80s ones.
It seems that in the mid to late 80s they offered them in only HPS but in the 1990s they brought the MH and MV ones back. I recall seeing an MV M250 FCO once. Either GE lazily only applied HPS in their spec sheets or they stopped making them for a bit.
Silverliner
Re: Did mercury vapor FCO fixtures not begin being made until the 90s? « Reply #6 on: Today at 09:12:50 AM » Author: Silverliner
They never stopped making MV FCOs until the 2008 MV ballast ban. Just not as common as HPS.
Electrician.
