We have 95 watt daylight tubes here in the USA that work just fine on your 100 watt gear (I've tried!). Might look for High Output Super Saver tubes if any US dealers are willing to export. Look for General Electric part 12131. Sylvania does not make 95 watt tubes in daylight, however, and they are usually my preferred brand. You could try Sylvania 25185 which is a 110 watt daylight tube. Others here have reported success using 110 watt tubes on 100 watt ballasts as long as you use a capacitor.
If you buy Sylvania tubes, you can just pull off the recessed double-contact base adapter and you have a bi-pin tube. However, the tube will be an inch or two short of 8'. Alternatively, when you purchase the tube, you could also buy a pair of recessed double-contact sockets to use with the tube.
Don't know how practical this would be, I'm just offering one more possibility if you can't find the right daylight tubes.
