Author Topic: 100w MV in a 50w ballast  (Read 4626 times)
paintballer22
120V/240V 60hz
100w MV in a 50w ballast « on: December 02, 2011, 02:39:47 PM » Author: paintballer22
Can I use a 100w  :mv: in a ballast for 50w  :mv: ?
Re: 100w MV in a 50w ballast « Reply #1 on: December 02, 2011, 11:48:26 PM » Author: funkybulb
it would underdrive the 100 watt  :mv: with severe arc tube blackening and can reduce ballast life.
H 38 ballast can be found cheap on ebay from time to time. beside small ballast is getting harder to find.
so it not recomended to do so.
Re: 100w MV in a 50w ballast « Reply #2 on: December 03, 2011, 01:51:05 AM » Author: Medved
Pulse-MH 70W ballast have the same characteristic as the H38, so you may use it. You should only deactivate the ignitor in the MH ballast.
