Author Topic: Want 100cm T12 bulbs  (Read 3026 times)
Carl M
Want 100cm T12 bulbs « on: February 27, 2012, 10:19:01 PM » Author: Carl M
Want for a display fixture which is European, but I am in US.  Looking for 5 or 6 bulbs, no other specifics required.  Guess I could use T8 too.
Re: Want 100cm T12 bulbs « Reply #1 on: February 28, 2012, 09:58:44 PM » Author: xmaslightguy
100cm converts to around 39-inches .. doing a quick Google search, looks like such a lamp does exist :)
Something like this for the T8 version? http://www.bulbs.com/espec.aspx?ID=13433
Lampwizard
Re: Want 100cm T12 bulbs « Reply #2 on: March 05, 2012, 04:49:44 PM » Author: Lampwizard
Google for TL 25W. These are European T12 tubes and 100cm long. There is also a T8 version called TLD 23W.
Philips colour 27: best fluorescent tube colour.
Michael
Re: Want 100cm T12 bulbs « Reply #3 on: April 21, 2012, 01:44:41 AM » Author: Michael
As well there is a also a 36W version of this lamp in the required length. So make sure which wattage the ballasts are.  ;)
If you realy need a T12 40W-1m version of it you have to look after Sylvania tubes as they're still available.
Good luck  :D
TL buis
Re: Want 100cm T12 bulbs « Reply #4 on: July 22, 2012, 05:03:27 AM » Author: TL buis
I have 25 watt version or 40W-1 meter available, you want?? Most of the time it is 25 watts, 40 watts was used for special size ceiling lights.. Measure the exact size between lampholders or check ballast
DetroitTwoStroke
Luke
Re: Want 100cm T12 bulbs « Reply #5 on: January 23, 2013, 04:16:48 AM » Author: DetroitTwoStroke
How about these Duro-Test tubes on ebay? 97cm 40 watt T12
