Author Topic: Wanted: 35/55w Lps NEMA bucket fixture  (Read 1557 times)
Wanted: 35/55w Lps NEMA bucket fixture « on: July 19, 2015, 04:14:28 PM » Author: Solanaceae
I was wondering if anyone has a Lps NEMA bucket fixture of 35/55w 120v they are willing to sell or trade. It doesn't need a lamp, as I am getting one from a fellow collector. Please PM me if interested. I would also be happy if I could get a 175w NEMA Mercury vapor bucket if I can't find the Lps bucket. Thanks.
« Last Edit: July 19, 2015, 04:18:19 PM by Solanaceae » Logged
lights*plus
George Liv Photo
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #1 on: July 20, 2015, 01:34:47 AM » Author: lights*plus
Don't think a 35w-55w LPS NEMA baucket is made any more. Try making your own:
www.ebay.com/itm/201285165282
www.ebay.com/itm/301373190373
www.ebay.com/itm/281577916037
WARNING: Bought 2 ballasts from last link..shipped loose in box..nearly trashed by the time they arrived.
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #2 on: July 20, 2015, 02:50:30 AM » Author: Solanaceae
Thanks. Does he ballast come with all of the required accessories? (Caps, bracket, etc)
lights*plus
George Liv Photo
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #3 on: July 20, 2015, 04:52:10 AM » Author: lights*plus
No capacitors! 14 microfarads are required and should be easy to find. Ballasts have welded brackets, 5" length exactly end to end, but probably too short for typical Nema heads. OCV is 430-530 Volts and they are HX-HPF autotransformer ballasts, no ignitors required.
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #4 on: July 20, 2015, 05:41:39 AM » Author: Solanaceae
I found this capacitor. Would it suffice? http://pages.ebay.com/link/?nav=item.view&alt=web&id=141722922038&globalID=EBAY-US
lights*plus
George Liv Photo
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #5 on: July 20, 2015, 03:15:58 PM » Author: lights*plus
Nope. Avoid motor run capacitors. My experience is they heat up very quickly, probably because they're oil filled. Advance, Magnetek or GE capacitors specifically made for HID lighting will do fine. Like these: www.ebay.com/itm/301564496382 www.ebay.com/itm/181219421497
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #6 on: July 20, 2015, 03:38:57 PM » Author: Solanaceae
The only problem with the second one is that it is rated for 300v instead of 450.
Will it function properly without capacitor?
« Last Edit: July 20, 2015, 03:44:39 PM by Solanaceae » Logged
lights*plus
George Liv Photo
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #7 on: July 21, 2015, 12:26:13 AM » Author: lights*plus
For the 35-55w ballast I linked above, 14μF is needed! Never tried it without capacitor!
And according to ballast data or info, a 240 Volt capacitor is enough. Both linked caps are fine & the one that shows free US shipping is actually the same I used (but I had for nearly a decade as it's used primarily for 150w HPS).
« Last Edit: July 21, 2015, 12:40:33 AM by lights*plus » Logged
Re: Wanted: 35/55w Lps NEMA bucket fixture « Reply #8 on: July 21, 2015, 03:47:34 AM » Author: Solanaceae
thanks. I found a GE cap designed for use with metal halide ballasts and will buy that.
