Author Topic: Redneck ballast rig  (Read 4665 times)
xelareverse
Redneck ballast rig « on: July 05, 2016, 03:18:39 AM » Author: xelareverse
How would I rig up a multitap HID ballast to run one of the tapped voltages?
Re: Redneck ballast rig « Reply #1 on: July 05, 2016, 07:47:23 AM » Author: wattMaster
There should be a "common" cable, I would connect that to neutral.
Then choose your desired voltage and find the wire for that voltage, and connect that to hot.
« Last Edit: July 06, 2016, 02:50:31 PM by wattMaster » Logged
xelareverse
Re: Redneck ballast rig « Reply #2 on: July 05, 2016, 08:44:45 AM » Author: xelareverse
These should be a "common" cable, I would connect that to neutral.
Thanks
Re: Redneck ballast rig « Reply #3 on: July 05, 2016, 08:52:54 AM » Author: wattMaster
Don't forget about general AC safety practices.
Re: Redneck ballast rig « Reply #4 on: July 05, 2016, 01:27:40 PM » Author: Solanaceae
Just don't overload or short the primary. The coils will het up almost instantly and then be dead.
Re: Redneck ballast rig « Reply #5 on: July 06, 2016, 04:36:56 AM » Author: Medved
Better use a slow blow fuse on the primary corresponding to the ballast wattage rating. If you overload it, most likely the fuse will blow first before anything bad happen to the ballast.
Or other (or an additional) option is to use a reversible thermal cut out, thermally coupled to the winding (that would be the more difficult part; important is the winding, not the core, as with heavier overload the winding heats up much quicker, so it has time to respond)
Re: Redneck ballast rig « Reply #6 on: July 06, 2016, 02:50:07 PM » Author: wattMaster
And add a GFCI too.
