Author Topic: LG eBay Lighting Finds 2018  (Read 7875 times)
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #30 on: August 19, 2018, 11:00:03 AM » Author: Cole D.
A Cooper 42W fluorescent area light on eBay. Pretty cool light, and I thought about getting. What's even neater is it has a NEMA wattage tag, which I hadn't seen on a fluorescent before.
Can this be arm mounted?
https://www.ebay.com/itm/Cooper-Lighting-42-watt-Fluorescent-Security-Light-Clean-New-Bulb/302757916997?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D7e35a08a0329473b8a802867270ec9ca%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D182398235676%26itm%3D302757916997&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Af95c708b-a3d0-11e8-8192-74dbd180caf3%7Cparentrq%3A531ede601650aad76c9da68bfff6e7c3%7Ciid%3A1
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #31 on: August 19, 2018, 11:01:07 AM » Author: Cole D.
Here's a beautiful GE radial wave light on eBay with green and white porcelain reflector and Ripley photocell:
https://www.ebay.com/itm/General-Electric-GE-1960s-Radial-Wave-Street-Light-Sunswitch-Photo-Control/183377315472?hash=item2ab223c690:g:qLkAAOSwndRbcHgb
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #32 on: August 19, 2018, 11:03:22 AM » Author: Cole D.
NOS 1998 GE Powr/Bracket - it's 250 W HPS but has the large 16" refractor:
https://www.ebay.com/itm/General-Electric-GE-Power-Bracket-250W-HPS-Street-Area-Pole-Light-Multi-Tap/183387762573?hash=item2ab2c32f8d:g:6BYAAOSw-LJbcyLg
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #33 on: August 19, 2018, 11:05:50 AM » Author: Cole D.
Very cool 1970s GE 201SA 175w MV with the older shape hood and painted
https://www.ebay.com/itm/Vintage-General-Electric-175-Watt-120V-Mercury-Vapor-Street-Light-New-Old-Stock/173437545423?hash=item2861aeebcf:g:zYgAAOSw6AlbQlKu
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #34 on: August 30, 2018, 09:55:57 PM » Author: Cole D.
Here's a MV GE 201SA on eBay. This is the same seller I got mine from, but this one is unpainted and it does have the refractor but there's a hole. I guess the smooth reflector must be original to these units.
GE MV Luminaire
They're also selling this GE yard light and a spare GE NEMA refractor assembly
GE Yard Light
GE Optical Assembly
« Last Edit: September 03, 2018, 01:23:30 PM by Cole D. » Logged
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #35 on: September 03, 2018, 10:37:25 AM » Author: Cole D.
Here's a GE 201SA HPS fixture. It's brand new, made last May. Not a bad price for $40 on a utility grade fixture. I don't know if it includes a bulb or photocell though. I don't believe it includes an arm.
The same seller also has some other fixtures including an American Electric Contempo HPS post top.
https://www.ebay.com/itm/GE-Sam-Roadway-Light-SAM1S1N21NV5ALN002-New/273431068233?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D0591f21c887e4918ba24cae2cee35f4a%26pid%3D100675%26rk%3D8%26rkt%3D15%26sd%3D372398803959%26itm%3D273431068233&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A4ba7ca46-af97-11e8-9011-74dbd1802be5%7Cparentrq%3Aa04986a61650a9c430a86443fff85910%7Ciid%3A1
« Last Edit: September 03, 2018, 01:19:14 PM by Cole D. » Logged
MissRiaElaine
Re: LG eBay Lighting Finds 2018 « Reply #36 on: September 03, 2018, 10:52:04 AM » Author: MissRiaElaine
Can I recommend the use of the link insertion facility, it makes links like the ones you quoted far easier to read.
All you need to do is type a left square bracket [ followed by "url=" (without the quotes) then insert the link. Add a right square bracket, then type a descriptive message, then another [ with "/url" (again without the quotes) and finish with a ].
This makes the link
look like here is some text describing the link which I'm sure you'll agree is much easier to read. Yes it's a little time consuming to do, but it makes for a much more readable message Smiley
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #37 on: September 03, 2018, 11:37:45 AM » Author: joseph_125
I believe eBay URLs can also be trimmed to get rid of the extra tracking fluff too. You can pretty much get rid of anything after the item number in the URL and it will still work. Here's the same URL but with all the fluff removed:
But yeah as Ria mentioned, using the forum url tag would result in a even neater link.
Then you can turn that URL in to a clickable link like this:
GE SA NEMA Light
takemorepills
Full Member
Re: LG eBay Lighting Finds 2018 « Reply #38 on: September 05, 2018, 06:49:35 PM » Author: takemorepills
Here's something pretty cool:
https://www.ebay.com/itm/Angelo-Lamparts-Lamp-Parts-Electric-Gas-Light-Converter-Bulb-35W-NOS-New-Vtg/253837375566?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I bought 2 of 'em, interested to see what they look like lit up. Not very expensive either! I'll post pics of these when I get 'em
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #39 on: September 14, 2018, 10:28:06 PM » Author: Cole D.
Here's a 400W GE Powr/Bracket on eBay. It looks like it could use some TLC but seller says it works.
GE Powr/Bracket
I didn't know there were 4 generations of these, so I guess I learned something.
boiler1011
Jr. Member
Re: LG eBay Lighting Finds 2018 « Reply #40 on: September 16, 2018, 04:27:12 PM » Author: boiler1011
GE Powr/Bracket
I would assume I have the latest generation PB, as mine was a late model, and I assure you it is not cheap or flimsy. It weighs a good 20ish pounds, and while the reflector isn't painted, it is very nice aluminum. The refractor is extremely thick plastic.
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #41 on: September 17, 2018, 09:44:49 PM » Author: Cole D.
Yeah I doubt they're lightweight. I think yours is a 1995 if I remember right? With GE cheapening their lights and moving production to Mexico after 2008, it's possible the latest Powr/Brackets in the last couple of years before they were discontinued were flimsier, but I doubt anyone has one to compare it.
boiler1011
Jr. Member
Re: LG eBay Lighting Finds 2018 « Reply #42 on: September 19, 2018, 01:45:19 PM » Author: boiler1011
Yeah it was a 4/95 build.
Full Member
Re: LG eBay Lighting Finds 2018 « Reply #43 on: September 22, 2018, 10:08:35 PM » Author: wide-lite 1000
I just bought this Powr/bracket date on ballast module is 8/96 so not that old but seems to be cleaning up nicely and works well doesn't weigh very much but then again I'm used to lifting cobra heads and insanely heavy wide-lite floods
Sr. Member
Re: LG eBay Lighting Finds 2018 « Reply #44 on: September 30, 2018, 04:50:10 PM » Author: Cole D.
Which Powr/Bracket did you buy? And the one on eBay has been relisted, at a higher price.
© 2005-2019 Lighting-Gallery.net | Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
