Author Topic: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!!  (Read 2741 times)
lightinglover8902
Sr. Member
GoL UCP_yo1gHzReqS19MjJMXUKg
The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « on: March 13, 2018, 04:49:05 PM » Author: lightinglover8902
Look what they did to this GE M250R2 streetlight. Just disgraceful!
https://www.ebay.com/itm/LED-Street-Light-from-GE-Including-Wireless/322262939716?hash=item4b085e3844:g:8v8AAOSwOyJX2sPv
But at least you can take off the LED stuff thats in it, what the seller said.
« Last Edit: March 13, 2018, 04:53:50 PM by lightinglover8902 » Logged
Sr. Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #1 on: March 14, 2018, 12:03:43 AM » Author: tolivac
That's the STUPIDEST thing I have EVER seen-I would gut that LED crap and put the orig HID back in-the antennas make it look utterly ridiculous!!!!Looks like something you would see on the cartoons!
Hero Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #2 on: March 14, 2018, 12:15:32 AM » Author: dor123
See here
I only working with the European date format (dd.mm.yyyy).
I lives in Israel, which is a 230V, 50hz country.
Hero Member
SodiumVapor 105843202020668111118 UCpGClK_9OH8N4QkD1fp-jNw majorpayne1226
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #3 on: March 14, 2018, 03:13:08 PM » Author: HomeBrewLamps
I think it is interesting.
~Owen
Mercury Vapor LampHigh Pressure Sodium Scavenger, Urban Explorer, Lighting Enthusiast and Creator of homebrewlamps Cool High Pressure SodiumMercury Vapor Lamp
lightinglover8902
Sr. Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #4 on: March 14, 2018, 03:36:18 PM » Author: lightinglover8902
Well I think its dum to put a LED Retrofit on a original HID fixture. No offence.
Miss Cuddly
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #5 on: March 14, 2018, 04:13:01 PM » Author: Miss Cuddly
That is a pure abomination.!!! Shocked
What on earth would you need Wi-Fi for anyway? Huh?
Hero Member
^homebuilt fixture
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #6 on: March 14, 2018, 07:37:10 PM » Author: xmaslightguy
Quote from: Miss Cuddly
To turn it into a spy device. maybe?
Or possibly just so it could be controlled remotely?
Colored Fluorescent's such as F40T12 Red or  Green or Blue are awesome...
Hero Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #7 on: March 18, 2018, 02:20:25 PM » Author: Ash
The wifi is not related to the lighting operation. It is either provided by the city for people to use. or for reading smart meters etc. The streetlight is however about the only thing installed in the street, getting power (without needing to install a new service for every wifi AP)
What is ridiculous about some of those wireless systems - They could of left the antenna inside the luminaire (in the optical compartment, or in case of luminaire body made of Fiber - anywhere in the luminaire) and it would work the same, there is no need to poke the antenna out...
Hero Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #8 on: March 18, 2018, 02:28:07 PM » Author: HomeBrewLamps
I think this is a viable idea. I liek the light, and if i had bought it, would probably leave it LED (at least until the panels finally burn out).
~Owen
lightinglover8902
Sr. Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #9 on: March 18, 2018, 09:53:07 PM » Author: lightinglover8902
I'll just change it to HID, period.
marcopete87
Sr. Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #10 on: March 28, 2018, 12:41:13 PM » Author: marcopete87
homemade conversion = no good
no heatsink = bad
5mm leds = worse
little (if none) insulation = worst.
toomanybulbs
Sr. Member
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #11 on: April 24, 2018, 06:26:55 AM » Author: toomanybulbs
its a demo unit.
5mm wont do squat up on a pole but close to the floor at a trade show they would be fine.
and good 5mm on a board with heavy copper traces will last.
problem is most 5mm are garbage.
unless cree,nichia,yuji,ect.
Hero Member
105555521242365640724 UCM30tBQDUECOV6VeG5W87Vg zfarmadillo
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #12 on: April 24, 2018, 08:10:20 PM » Author: Lumex120
Looks like someone tried to turn this into a PC case mod judging by all those electronics in there.  Shocked
Any machine is a smoke machine if you operate it wrong enough.
F96T12 DD VHO
Sr. Member
Alex//I love both Iceland and CO
https://www.facebook.com/ DJ_Unrealeased UC2Uv7t9KgigOoT6blff2t3w Jack_u_aliens
Re: The worst LED Retrofit ever on a GE M250R2 on ebay!!!! Disgraceful!! « Reply #13 on: April 26, 2018, 05:17:16 AM » Author: F96T12 DD VHO
I would try to upgrade it to a HID of some sort
That looks painful to touch
Fluorescent Lamp T12/T17 Fluorescent Lamp
Snapchat: EvanT12/Dj I.D. I can conduct 120VAC
High Pressure SodiumMercury Vapor LampHigh Pressure Sodium
Þetta er Mackenzie eða F96 GF, ég elska lýsingu og mun skjóta upp á LG sem Kenzie
Check out my Socials
© 2005-2019 Lighting-Gallery.net | Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
