Author Topic: What would be the best way to power a 50 watt mercury vapor lamp?  (Read 6530 times)
Fluorescent05
Zack
What would be the best way to power a 50 watt mercury vapor lamp? « on: October 29, 2018, 10:40:16 PM » Author: Fluorescent05
I looked all over eBay and can't find a proper 50 watt mercury vapor ballast. What would be the best alternative way to power a 50 watt mercury vapor lamp? (No wimpy F40T12 ballasts either)
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #1 on: October 29, 2018, 10:54:07 PM » Author: funkybulb
50 watt ballast do show up now and then
How ever there a few ways to power them
using 39 watt MH ballast to power them
with out a ignitor.  or use a European 58 watt
fluorescent choke on 240 volts.
those F40 Fluorescent ballast wont cut it
cause it 430 mA and mercury lamp need at least
630 mA to run.
Fluorescent05
Zack
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #2 on: October 29, 2018, 11:08:42 PM » Author: Fluorescent05
For the F58T8 fluorescent choke option, would it work running on 240v 60hz instead of 50hz? Also, are 120v 60hz to 240v 60hz step up transformers available?
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #3 on: October 30, 2018, 08:06:52 AM » Author: funkybulb
Yes  you will need a step up transformer. and I have  found transformers at restores.  mine Is a radio shack
transformer powered backwards with a GFCI protected
suicide cord from old hair dryer cord.  and i cut EU plug
off transformer input to a Terminal block.  that transformer been powering my 8 foot pop pack
from UK.  how ever any ballast design with 50 hz and
have a leading capaciitor.  like my 8 foot pop pack does
it will need a reduce cap value change cause current will rise on 60 Hz due leading cap.  how ever just running a 50 Hz choke on 60 Hz is no probems.  it runing 60 Hz to
50 Hz what satuated them. my new home will have 240 volt 15 amp outlet for expeirments and 240 volt plug in lighting circuit.  since power conpany gives you 240/120
volt coming into the homes anyway.
Fluorescent05
Zack
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #4 on: October 30, 2018, 03:51:33 PM » Author: Fluorescent05
One more question: Would a UK 6 foot 70 watt T8 choke work to power 75 watt mercury vapor lamps?
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #5 on: October 30, 2018, 11:30:41 PM » Author: wide-lite 1000
search 1010-236-c-tc  on eBay the seller has 3 of them for $55 obo they are 120/277 and in a florescent ballast case I'm going to get one eventually but not 3, hope this helps!
Fluorescent05
Zack
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #6 on: October 31, 2018, 07:11:08 AM » Author: Fluorescent05
Thank you so much! ;D ;D
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #7 on: November 15, 2018, 06:37:27 PM » Author: wide-lite 1000
I just ordered one of those eBay ballasts today seller accepted $40.00 offer + free shipping in US
Fluorescent05
Zack
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #8 on: November 15, 2018, 09:37:11 PM » Author: Fluorescent05
Well at least it went to a fellow collector. They were down to the last ballast and I just bought it. Sorry to any other people that might have wanted it.
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #9 on: November 16, 2018, 06:03:09 PM » Author: wide-lite 1000
glad you got one IDK who got the other, Hopefully it was one of us
Fluorescent05
Zack
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #10 on: November 16, 2018, 08:03:05 PM » Author: Fluorescent05
Hopefully it was someone who knows how to actually use it.
Re: What would be the best way to power a 50 watt mercury vapor lamp? « Reply #11 on: November 16, 2018, 08:14:03 PM » Author: wide-lite 1000
exactly my thought!
