Author Topic: WANTED: outreach arm to fit 76mm column  (Read 1826 times)
d3anio97
Enginerding bright things since 2011
ATL TheSOXMania
WANTED: outreach arm to fit 76mm column « on: February 08, 2019, 04:12:35 AM » Author: d3anio97
I'm on the lookout for anyone who has or can help me get hold of an older style outreach arm similar to the ones used in the 1990s when new SOX installations were being undertaken.
I need it for my newly welded column so I can mount my Philips MI-26 onto it without having to search for a post-top adapter
As mentioned in the title it needs to have a 76mm mount point as that's the diameter of the steel column I have welded.
What if I told you you could save 100% of your street lighting budget? Don't believe me? Buy an LED street light and run it for a week. the results will leave you in awe. (Aaaaaaand maybe wondering why you swapped that 70w SON)
