Author Topic: Yield Lab digital ballast problem  (Read 3737 times)
Yield Lab digital ballast problem « on: March 29, 2019, 08:55:41 PM » Author: HomeBrewLamps
My friend gave me a grow light ballast to try and fix, it's a yield Lab 1000watt HPS/MH ballast with a brightness selector and alot of electrical stuff inside I don't quite understand...
The issue at the moment is it does not output any voltage whatsoever, however the cooling fan still spins. What do I need to replace or do to make this ballast work again?
Re: Yield Lab digital ballast problem « Reply #1 on: March 30, 2019, 01:17:48 AM » Author: tolivac
I have a few Yeild Lab,Growers Choice ballasts.when a digital ballast is first energized-the digital circuits in the ballast do a self check to see if they work properly.If there is faults in the circuits or actual ballast circuits the ballast shuts down.Does the ballast have any sort of indicator lights on it that light to tell you what its doing?Is there a bulb connected to the ballast-many of these digital ballasts won't activate unless a bulb is connected.Look on the Yeild Lab website for info on your ballast.They may be able to tell you whats going on with the ballast.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Yield Lab digital ballast problem « Reply #2 on: March 30, 2019, 11:51:55 AM » Author: Binarix128
I think is best to use a magnetic, the magnetic don't have electronic components inside (capacitors, transistors), but need more components and have more weight.  :)
If yow want to repair the digital ballast, you need to find the overloaded component and replace it (normally in the circuits fails the capacitors and the integrated circuits)
Binarix128
220V AC 50Hz, NTSC
Re: Yield Lab digital ballast problem « Reply #3 on: April 01, 2019, 08:26:25 PM » Author: Binarix128
When I mean "to use magnetic ballast" I say you can use a limited transformer as ballast.
