Author Topic: What are your lighting pet peeve?  (Read 84316 times)
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: What are your lighting pet peeve? « Reply #75 on: March 14, 2024, 06:12:05 AM » Author: LightsAreBright27
Even for me, who has gotten used to 6500k lights, higher temps remind me of old hospitals. Not just led, even cheap fluorescent tubes that come with battery lanterns are also offenders.
245v 50Hz
Re: What are your lighting pet peeve? « Reply #76 on: March 14, 2024, 09:34:04 AM » Author: Mandolin Girl
@RRK:
That was one of the worst things that could happen to me, I suffer from night blindness, and the high colour temperature means I struggle to see clearly.  :(
Under sodium lighting, particularly LPS, I have no problems at all.! :lps: :love:
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: What are your lighting pet peeve? « Reply #77 on: March 14, 2024, 01:17:54 PM » Author: LightsAreBright27
Another pet peeve I have about lighting is the amount of dead lamps when multiple are present (not only leds). A poorly maintained office building where the rooms are good but the hallway lights are half dead, or flickering. Led was supposed to solve this problem but since making a high voltage low amp power supply and putting the leds in series is easier than making a low voltage high amp power supply and putting the leds in parallel.
245v 50Hz
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: What are your lighting pet peeve? « Reply #78 on: April 13, 2024, 07:03:50 AM » Author: LightsAreBright27
This may be a little irrelevant but it further enforces on the problem where the best working lamp breaks while the eol/bad condition one is fine. When I was extracting two VFDs, the one with small pins and chipped glass survived but the best condition one with long pins lost vacuum (black spot=vacuum good & white spot=vacuum loss).
245v 50Hz
UChBXesrxSalDTp79uMtfDvA
Re: What are your lighting pet peeve? « Reply #79 on: May 03, 2024, 04:10:55 PM » Author: WorldwideHIDCollectorUSA
Another pet peeve that has really been bothering me is that I often get frustrated whenever I encounter collectors who give contradicting advice when it comes to lamp/ballast combinations in which a European collector might claim that the setup is “compatible” and “safe” while a North American collector would claim that the same lighting setup is “incompatible” and “dangerous”. Has anybody else ever dealt with a similar situation like I have been facing?
Laurens
Re: What are your lighting pet peeve? « Reply #80 on: May 03, 2024, 04:53:44 PM » Author: Laurens
The most important thing to avoid such things is to make your question as good as possible. This means for lighting devices that you should include a datasheet with current and voltage, specify your mains voltage and frequency etc.
For ballasts, this is not always easy to find. They're also often designed to be 'user friendly' which means that the current/voltage is not always specified, only 'X watts'. When the input from the manufacturer is vague, the output from people who are trying to help will also be vague. Garbage in, garbage out. Vossloh Schwabe often prints the different compatible lamps including their running currents on the ballasts, which is awesome, but that's far from universal.
There are also different types of ballast. Over here, the most common one is a simple coil in series with the tube. Leakage transformers are very rare here. So that kind of stuff you also have to take into account to specify.
If everything is quite vague, it will take some discussing and potentially conflicting opinions before you get to a workable solution. That's the reality of online collaboration between different people. I've seen on many occasions people getting angry and moan at the people who are voluntarily trying to help them with electronics engineering and repair related questions and are discussing amongst themselves to figure out what's right. And to those i can only say:
Go find an engineering/consultancy firm, and specify that you only want one single answer and one answer only - even if that means that you might miss some important nuance.
« Last Edit: May 03, 2024, 04:56:14 PM by Laurens » Logged
lightinggalleryuser33450
Re: What are your lighting pet peeve? « Reply #81 on: December 01, 2024, 11:05:29 PM » Author: lightinggalleryuser33450
when a fixture housing can physically fit larger lamp and gear, but a lower wattage setup is installed
Re: What are your lighting pet peeve? « Reply #82 on: December 01, 2024, 11:18:57 PM » Author: Cole D.
Replacing quality vintage fixtures with integrated LED rubbish, designing modern decorative fixtures with integrated LED instead of replaceable lamps, and also retrofitting quality fixtures with LED only to replace them late with LED fixtures!
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: What are your lighting pet peeve? « Reply #83 on: December 02, 2024, 05:06:07 AM » Author: LightsAreBright27
Sometimes, they also replace older good quality leds with a cheap new leds. Compare early led bulbs with metal heatsinks to plastic ones now.
245v 50Hz
Re: What are your lighting pet peeve? « Reply #84 on: December 12, 2025, 01:07:43 PM » Author: WorldwideHIDCollectorUSA
Another lighting pet peeve that bothers me is when metal halide lamps and other lamps with burning position restrictions are operated in the incorrect burning position. For example, a base up only burn metal halide lamp being operated horizontally.
Re: What are your lighting pet peeve? « Reply #85 on: January 27, 2026, 04:27:18 PM » Author: WorldwideHIDCollectorUSA
Another thing I sometimes find irritating is when collectors claim that poorly documented examples of lamps and lighting equipment do not exist or when collectors say that information in technical documents is incorrect even when I try to share my proof citing the technical documents I found my information from and they get defensive and tell me that I am wrong even if I tell them where to find the information.
« Last Edit: January 27, 2026, 10:53:35 PM by WorldwideHIDCollectorUSA » Logged
Lightingeye60
Re: What are your lighting pet peeve? « Reply #86 on: September 27, 2026, 11:10:55 AM » Author: Lightingeye60
When LED bulbs fail prematurely. That’s one of my pet peeves.
BuzzyBallast
Electrician with a heart like a raccoon
Re: What are your lighting pet peeve? « Reply #87 on: September 27, 2026, 10:32:01 PM » Author: BuzzyBallast
When an HPS lamp is at EOL and is cycling, drives me completely crazy.
Also streetlights lit up in the daytime because the PC is bad, really annoying.
Or if I'm really having a bad day a light on in the daytime and a cycling lamp, I've seen it happen
Lightingeye60
Re: What are your lighting pet peeve? « Reply #88 on: September 28, 2026, 03:28:06 AM » Author: Lightingeye60
Yep. That’s one of my pet peeves as well.
Another pet peeve of mine is very dim and worn out mercury vapor (or metal halide) lights that are uselessly dim. Poorly maintained street lights also are a pet peeve.
Lightingeye60
Re: What are your lighting pet peeve? « Reply #89 on: September 28, 2026, 04:09:01 AM » Author: Lightingeye60
More of my pet peeves include:
Dim and worn “greened out” mercury vapor lights that are useless.
Multiple color temperatures in one fixture.
Yellowed or cracked refractors
Loose light fixtures or fixtures that are hanging from the ceiling
Fixtures with missing covers or refractors.
Flickering EOL LED lights that don’t get replaced.
Restricted burning position MH lamps used in the wrong burning position
Fixtures with the wrong wattage of lamp (e.g. putting a 250W HPS lamp in a 400W fixture).
NEMA heads that are sideways or pointing directly towards the sky.
Floodlights that point directly into your windows.
Acorn and globe fixtures that shine more light up and sideways than on the road.
Those are pretty much all my pet peeves.
« Last Edit: September 28, 2026, 04:13:53 AM by Lightingeye60 » Logged
