November 11, 2026, 10:46:19 AM
General
General Discussion
Can a 26w PL run in 40w ballast?
Topic: Can a 26w PL run in 40w ballast? (Read 3233 times)
Binarix128
220V AC 50Hz, NTSC
« on: August 31, 2019, 12:30:39 AM »
Binarix128
Sound crazy, but it's working to me, at least these moments. What happen if I run a 26w biax PL in a 40w fluorescent ballast? The lamp life will be more short? The ballast life will be more short? The PLs will pop at few hours of working?
Re: Can a 26w PL run in 40w ballast?
« Reply #1 on: August 31, 2019, 01:37:41 AM »
The lamp will overheat, so beside the short lefe, its color will be off (green tint) and efficacy low, both because of too high mercury pressure in the discharge.
« Reply #2 on: August 31, 2019, 02:45:12 AM »
now run a 5 watt lamp on a 40 watt ballast!
« Reply #3 on: August 31, 2019, 03:55:22 AM »
The lamp specs are approx 95V 320mA. Is 25W T12 close in spec ?
