Author Topic: Looking for H-33 high bay  (Read 8318 times)
RadiantMV
Looking for H-33 high bay « on: May 11, 2020, 04:47:10 PM » Author: RadiantMV
I'm looking for a high bay that can be used with a 400 watt H-33 mercury lamp. The ballast should have a plug on the end for easy use. Thanks!
Re: Looking for H-33 high bay « Reply #1 on: May 11, 2020, 05:35:39 PM » Author: Lumex120
Check your local craigslist for 400w metal halide high bay lights. They can run 400w mercury lamps too. If it's pulse start you'll have to disconnect the ignitor but otherwise it will be fine.
Re: Looking for H-33 high bay « Reply #2 on: May 11, 2020, 10:53:10 PM » Author: wide-lite 1000
Anything M-59 or H-33 will work with no modifications.
RadiantMV
Re: Looking for H-33 high bay « Reply #3 on: May 12, 2020, 02:51:12 PM » Author: RadiantMV
how do I tell if its pulse start? Most adds I find dont list it.
Re: Looking for H-33 high bay « Reply #4 on: May 12, 2020, 02:57:21 PM » Author: Lumex120
If it's pulse start the ballast code will be something other than M59. You can also open up the ballast enclosure and see if there's an ignitor.
Re: Looking for H-33 high bay « Reply #5 on: May 12, 2020, 08:05:34 PM » Author: joseph_125
400w Pulse start would be M155. The easiest way to tell the ballast type is to ask the seller to take a picture of the fixture nameplate. I find a lot of local sellers will mistake MH for MV or even HPS at times.
RadiantMV
Re: Looking for H-33 high bay « Reply #6 on: May 20, 2020, 06:50:04 PM » Author: RadiantMV
Update: i bought a lithonia m59 high bay and it worked! Thanks everyone!
