Author Topic: What do you use as nightight  (Read 1212 times)
Oliver
All Fluorescent Lighting / Sign Lights
Re: What do you use as nightight « Reply #30 on: June 28, 2020, 09:38:27 AM » Author: Oliver
I have a 4w Magnetic ballast fluorescent note checker light that I leave on 24/7. I use it as a night light. The fitting is designed for a BLB black light tube but I just put a Standard White tube in and it works nicely as a night light.
Wireman
Jr. Member
Re: What do you use as nightight « Reply #31 on: June 28, 2020, 06:02:33 PM » Author: Wireman
For me, it has to be the TV with the volume down low. Watching an old show helps me fall asleep and it's reassuring if I wake in the middle of the night.
"Hell, there are no rules here. We're trying to accomplish something." - Thomas Edison
"Something always fires the light that gets in your eyes." Neal Peart
Binarix128
Sr. Member
220V AC 50Hz, 525@29,970i NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: What do you use as nightight « Reply #32 on: June 28, 2020, 06:09:08 PM » Author: Binarix128
Set your TV in warm white configuration, it'll help you to sleep easily, and/or turn the brightness all the way down.
LED will never beat other lamps. Incandescent Lamp High Pressure Sodium Mercury Vapor Lamp
Color changing lamp Creator of CaptureCommons Color changing lamp
Wireman
Jr. Member
Re: What do you use as nightight « Reply #33 on: June 28, 2020, 06:20:19 PM » Author: Wireman
Thanks I'll keep that in mind. Actually I'll take any advice I can get on being able to sleep better.
Hero Member
Re: What do you use as nightight « Reply #34 on: June 28, 2020, 06:30:27 PM » Author: sol
Some people have had success in wearing glasses with orange lenses for couple of hours before going to bed. I cannot attest to this as I have never tried, but I like to limit my exposure to lamps that are above 3500K for a while before retiring for the night.
Binarix128
Sr. Member
Re: What do you use as nightight « Reply #35 on: June 28, 2020, 06:42:19 PM » Author: Binarix128
You can use cheap yellow building glasses, are very good filtering the blue light. Avoid any L*D, and CFL before going to bed, use incandescent or halogen in your room.
Wireman
Jr. Member
Re: What do you use as nightight « Reply #36 on: June 28, 2020, 06:51:24 PM » Author: Wireman
I have a daylight LED bulb in my bedroom lamp. I like the cool color but I didn't know that it could cause a problem. I've read about how blue light can affect sleep but wasn't sure if it was true.
Hero Member
Re: What do you use as nightight « Reply #37 on: June 28, 2020, 06:54:37 PM » Author: sol
Try replacing it with a low wattage incandescent for a couple of weeks to see if things improve.
Wireman
Jr. Member
Re: What do you use as nightight « Reply #38 on: June 28, 2020, 06:59:46 PM » Author: Wireman
Thanks! I'll certainly give it a try.
Binarix128
Sr. Member
Re: What do you use as nightight « Reply #39 on: June 29, 2020, 10:00:22 PM » Author: Binarix128
If you wanna even sleep better, read magazines of your interest instead of TV shows while listening to calm music, and leave the computer, TV or whatever an hour before going to sleep, and buy a lamp with a dimmer and a 40w incandescent bulb, so you can regulate the light while you read. And don't listen to heavy or dead metal before going to bed.  LOL
Wireman
Jr. Member
Re: What do you use as nightight « Reply #40 on: June 29, 2020, 10:43:01 PM » Author: Wireman
Thanks I appreciate all the help I can get. I'll certainly try all of your advice. Nope no heavy metal at bedtime maybe classical. Again thanks for all the advice. Gotta get rid of that daylight LED in my room and everywhere else.
Binarix128
Sr. Member
Re: What do you use as nightight « Reply #41 on: June 29, 2020, 10:59:49 PM » Author: Binarix128
You're welcome! You should considerate to use your daylight L*Ds in a bucket of salty water fixture.  LOL
Wireman
Jr. Member
Re: What do you use as nightight « Reply #42 on: June 29, 2020, 11:08:38 PM » Author: Wireman
Best advice I've heard all day! Wonder if I could borrow Mr. Smashy from Ria?
Binarix128
Sr. Member
Re: What do you use as nightight « Reply #43 on: June 29, 2020, 11:33:07 PM » Author: Binarix128
Or my heavy fully metal Mr. Smashy. 0% plastic, 0% wood, 100% hard not chromated steel.  Grin
There's not L*D that can resist my Mr's smashy.  LOL
Hero Member
Mainly the electrical side of things
missriaelaine
Re: What do you use as nightight « Reply #44 on: June 30, 2020, 05:18:38 AM » Author: sox35
He's on his way  LOL
Ria in Aberdeen
It'll be all right in the end, and if it isn't all right, it isn't the end Love
© 2005-2020 Lighting-Gallery.net | Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
