March 29, 2024, 01:36:39 AM
General
General Discussion
Fluorescent Light question,
Topic: Fluorescent Light question, (Read 1027 times)
LINKS
« on: June 29, 2020, 06:03:47 AM »
LINKS
I have a twin 3ft tube Fluorescent street light from the 60s It has the super heavy ballast transformer, will that work ok with modern tubes? Someone was saying it’s a fire hazard.
Oliver
All Fluorescent Lighting / Sign Lights
Re: Fluorescent Light question,
« Reply #1 on: June 29, 2020, 06:26:06 AM »
Oliver
As long as it's the same wattage that the ballast specifies, I don't see a problem.
If you reply to me, please "reply with quote" so I am notified of your reply!
« Reply #2 on: June 29, 2020, 06:54:43 AM »
If the wiring or connection points are failing, then you might have a hazard.
If you run it for several hours and then measure the temperature of the components, you'll get to see if it heats up too much or not.
« Reply #3 on: June 29, 2020, 02:32:33 PM »
Any equipment can fail. It must be built in a way that safely contains the fault - A streetlight does this if it is run with all required covers in place
