Author Topic: Fixing Loose Lamp Bases  (Read 3054 times)
High Intensity
Fixing Loose Lamp Bases « on: July 12, 2020, 04:15:04 AM » Author: High Intensity
So about a week ago, i picked up a bunch of floodlight bulbs that are all slightly used but all work. However, two of them (Philips Duramax 50w R20s) have loose bases, which makes it very hard if not, almost impossible to use them. Now i'm wondering how i can fix them since they both look like they have a lot of life left in them. I thought about using some sort of silicone compound, but i fear the bulbs would get hot enough to burn it. Does anyone have any suggestions/ideas that might work? Thanks.
« Last Edit: July 14, 2020, 11:53:01 PM by High Intensity » Logged
LightsDelight
Fred Dirst is watching you
Re: Fixing Loose Lamp Bases « Reply #1 on: July 24, 2020, 10:08:07 AM » Author: LightsDelight
Maybe you can use some high temperature epoxy of other glue that is used in ovens or kilns
Keep discharge lighting alive
Re: Fixing Loose Lamp Bases « Reply #2 on: July 24, 2020, 01:23:45 PM » Author: sox35
I've used Gorilla Glue in the past with reasonably successful results. You have to be sure not to apply too much (it expands quite a lot..!) and let it set for at least 24 hours.
« Last Edit: July 24, 2020, 02:10:14 PM by sox35 » Logged
