Author Topic: Pesky light switch  (Read 14406 times)
Bulbman256
Kick the AI scrapers off LG
Bulbman256
Re: Pesky light switch « Reply #15 on: April 07, 2021, 07:20:08 PM » Author: Bulbman256
Just finished it up, as i suspected the issue was a loose backstab, went ahead and redid all the switches over to screw terminals. 8)
LightsoftheWest
SRP for life.
streetlightian
Re: Pesky light switch « Reply #16 on: April 07, 2021, 07:41:50 PM » Author: LightsoftheWest
Someone's going to be happy about that. :mrg: ;)
LG's North American luminaire identification specialist
Desultory13
Re: Pesky light switch « Reply #17 on: April 07, 2021, 07:58:27 PM » Author: Desultory13
Alright! Good job my man! Future electrician here! 8)
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #18 on: April 07, 2021, 10:08:42 PM » Author: Bulbman256
Ahh thanks! :D :-[ That's what i plan on doing! 8;)
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #19 on: April 08, 2021, 09:46:24 PM » Author: Bulbman256
The saga continues! I have a 4 way switch in my living room that controls some cans and it has been sorta broken, you cna use it but its stiff and will not go all the way in one direction, and is not aesthetically appealing because of that. Tomorrow i am going to grab a commercial 4 way and slap that sucker in! 8)
Desultory13
Re: Pesky light switch « Reply #20 on: April 08, 2021, 09:56:08 PM » Author: Desultory13
Yep. Sounds like you got a switch going bad.
Here's something to really keep in mind. Each pair of screws on the new switch may not be in the same position as on the old switch.
So I strongly recommend that you label each wire before you remove it and look carefully at the labeling of each pair of screws on the new switch.
I know that may sound complicated but it's not that bad other than stuffing it back into the box.
Good luck, you can handle it buddy!
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #21 on: April 08, 2021, 10:21:56 PM » Author: Bulbman256
Thanks for the advice jamie, will keep that one in mind tomorrow. 8) :love: It's a three gang box that feeds another set of cans and a fan, all single pole switches. always wondered how 4 way switches worked until i found out it's a weird wiring of a DSDP switch. :P Also if anything else is backstabbed, I'll take care of it. :D
Desultory13
Re: Pesky light switch « Reply #22 on: April 08, 2021, 10:34:34 PM » Author: Desultory13
Something else to keep in mind if you get a Leviton 4way, which I recommend, one pair of screws will be darker than the other pair.
The 2 traveler wires from one cable goes to the darker pair.
While your 2 traveler wires from the other cable go to the pair of lighter color screws.
But again it does help to label each wire and check the screws on the new switch.
Yes since you have the box open if you see any backstabs on the other switches, a little more effort now will save a lot of aggrivation later.
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #23 on: April 10, 2021, 01:15:26 PM » Author: Bulbman256
Well I changed the switch just fine and wired it right, but when I installed it in the box it didn’t want to go all the way up! There must be some dumb issue with the box, the old switch is still stiff but mostly works and the new one is more smooth so idk. >:( :curse:
Desultory13
Re: Pesky light switch « Reply #24 on: April 10, 2021, 01:27:10 PM » Author: Desultory13
The box is plastic right? It could be warped out of shape and possibly exerting pressure on the switch.
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #25 on: April 10, 2021, 01:37:01 PM » Author: Bulbman256
It is, although my mom says something must be misaligned in the wall and its not worth the trouble to fix. :-\ The issue doesn't seem to happen to the single pole lights switches. :P :wndr:
Desultory13
Re: Pesky light switch « Reply #26 on: April 10, 2021, 01:42:33 PM » Author: Desultory13
I agree. Replacing an existing box is an absolute nightmare and it's something that you don't do unless it's absolutely necessary.
I remember a recent job where I replaced an existing plastic 3gang box because it had to be changed to a 4gang for an additional switch!
Bulbman256
Bulbman256
Re: Pesky light switch « Reply #27 on: April 10, 2021, 04:11:06 PM » Author: Bulbman256
Was there no room to install a double switch? :-\
Desultory13
Re: Pesky light switch « Reply #28 on: April 10, 2021, 04:17:34 PM » Author: Desultory13
The customer hated that idea and felt that the 4way was more professional in appearance.
Somehow I got lucky, no major problems and it only took about 2 hours.
High Intensity
Re: Pesky light switch « Reply #29 on: April 10, 2021, 10:40:38 PM » Author: High Intensity
I hate to butt in, but when growing up, I HATED 4-way switches, because the two main in my parents house had an issue where neither of the 3-way switches worked if the 4-way switch was in a certain position, I later learned that both 4-way switches in my parents house were broken, hence why they would not work properly, so recently, I finally replaced both switches, and now they work as you would expect.
In case anyone's wondering, the broken switches were early 2000s Leviton Decora 4-way switches, I replaced the first one a couple of months ago, and the second one a few days ago.
